F250 Trailer Brakes - Ford Truck Enthusiasts Forums
F250 Trailer Brakes
Old 05-29-2012, 02:38 PM
captnko captnko is offline
captnko is starting off with a positive reputation.
F250 Trailer Brakes
I have a 2005 F250 Power stroke w/ brake controller installed. There is no voltage to the trailer brake (blue wire) pin. I've checked all of the fuses and they appear to be okay. Any ideas?
Old 05-29-2012, 04:28 PM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
Quote:
On an 05 with the TBC from the factory, you need to be moving I believe it is over 10 mph to get a reading at the pin. You can't just push the pedal while sitting still. As I recall it is the same thing using the manual override.
It is pretty common for folks to think their TBC is not working because of this feature which was changed in later models. Are you getting an error message while towing?
Steve
Old 05-29-2012, 05:21 PM
While towing the trailer, the brakes do not work (everything else works - brake lights, blinkers, tail lights.)
I occasionally get an error message to "check trailer" but I know its not the trailer because I have since hooked it up to two other vehicles and the brakes work fine.
Old 05-29-2012, 05:41 PM
RV_Tech's Avatar
Couple of things. Number one - when you are towing, if you activate the brakes manually do they work. This point is extremely important because you can not feel the trailer brakes working given the controller uses an accelerometer which mimics the stopping of the truck, when using the brake pedal. You simply can not feel the brakes on the trailer working with any of the new controllers either OEM or aftermarket. They really are that good. If they trailer brakes works manually, your controller needs to see a dealer, pure and simple. If manual also does not work, again this is a connection issue.
Number two - "check trailer" normally comes up due to the connection between truck and trailer. It does not mean the trailer brakes are not working. It means the TBC in you truck is looking for a set resistance from the magnets to tell it everything is working as it should and it is not getting the correct resistance. This is almost always a plug issue or a grounding issue between the truck and trailer. The controller is the least likely suspect in this situation.
Steve
Old 05-29-2012, 05:58 PM
The trailer brakes do not operate when the controller is activated manually or when the brake pedal is applied. According to what you are saying, that means it is a connection issue or a grounding issue. The thing that has me confused is that when I hook my trailer up to other trucks, everything works fine. I'll try to borrow another trailer to make sure it is not my trailer.
Old 05-29-2012, 07:08 PM
RV_Tech's Avatar
It's not your trailer. It is most likley the connection on your truck. On the Ford seven pin connection the back of the plug is exposed to water and it is not unusual for the pins to be nearly or completely rusted off on the back side.
You don't have to tow your trailer to check the brakes. If your trailer battery is good, just pull your break-away pin and the trailer brakes should lock up and you will not be able to move it. If you test this way, you absolutely must leave your seven pin on your trailer disconnected from your truck..
Steve
2008 f250 brake controller Burdpete 1999 to 2016 Super Duty 11 04-10-2016 04:24 PM
F250 Brake Controller - Upgrading trailer to disc brakes phydeauxman 1999 to 2016 Super Duty 1 03-13-2016 02:50 PM
Electric brake issue rusbukt Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 2 01-31-2016 07:35 PM
2006 F250 Brake Controller brenthottle 1999 to 2016 Super Duty 1 07-07-2013 02:27 AM
integrated trailer brake controller kylebryan 1999 to 2016 Super Duty 10 09-01-2010 09:38 PM
Tags
2003, 2004, 2005, brake, brakes, disconnect, f250, ford, grounding, message, operation, problem, towing, trailer, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
