Speed Compensated Volume Control - Ford Truck Enthusiasts Forums
Old 05-29-2012, 11:49 AM
Captbs32's Avatar
Captbs32 Captbs32 is offline
Captbs32 is starting off with a positive reputation.
I have a 2009 Ford Escape. I was wondering if I could re-Program or there was a component that could be added to have the speed compensated volume control. It is a XLT package w/o the feature.
Is there a way to get that on the vehicle?
Old 06-14-2012, 12:07 AM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is offline
Frankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to all
Swap the radio for one that has it.
Scroll through the options on the "menu" button on the radio. Speed volume is listed as "speedvol." If it's set to "zero" (0) it won't function, even if it's present.
There's an off chance that if the vehicle didn't come with it "stock," it won't have the wiring harness pin for the speed signal. But given Ford's preference to not stock multiple harnesses, I'd bet it's there, just not used.
-blaine
Problems with factory radio... Lebowskii 2009 - 2014 F150 5 01-11-2017 06:59 PM
Speed Sensitive Volume Control pikapp 2015+ F150 4 12-23-2015 04:44 PM
2004 Ford Explorer Steering Wheel Controls Funky Wranglin4Life Explorer, Sport Trac, Mountaineer & Aviator 1 10-30-2014 01:07 PM
speed compensated volume control Captbs32 Escape & Escape Hybrid 1 05-29-2012 02:07 PM
Steering Wheel Volume Control Fail - Maybe W7PSK 6.7L Power Stroke Diesel 9 03-22-2012 11:35 AM
Tags
2011, 2012, compensated, compensation, control, edge, escape, ford, limited, speed, volume
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
