Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-29-2012, 12:03 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
Garage is empty, add now
timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.timmyboy76 has a very good reputation on FTE.
timmyboy76 seadooya
WVO smells like PUKE
Well this sucks, i've been collecting this wvo for 8+ weeks now, and to tell ya, i could've ran straight from their fryer. Oils' been a golden clear color the whole time, and couldn't been more stoked. So, today, after collecting it last saturday, been sitting waiting for it to be filtered into my holding bin (same procedure as always), i removed the lid and couldnt believe what i saw and especially smelled. Nasty crap floating on top, and the puridy of the oil was just nasty. After tapping off 5gal, i couldnt take the smell anymore. Its like, the restaurant threw a party and everybody, who couldnt handle their liquor, decided to upchuck into my holding barrell.
Done, some "searching" on this "smell" of oil, but really no solid info as to where to go from here with it. Should i discard it, or try and clean it up?
I tranferred it into another 20gal barrell, and the last 5gal was almost unbearable with the smell and what looked like grey clobs from what looks like, started taking on life....in the blind on this one guys. Any info would really be great...thanks
__________________
TIM...PAA#113....plenums inserts, hpx, frx, 50 cent, gauges, trans-coolant-oil DIY by-pass systems, H/H mod, DIY WVO system 156k and counting
  #2 (permalink)
Old 05-30-2012, 04:44 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
I used to get batches like that when the place used Hydrogenated oil. It still worked, but usually titrated higher and didn't have as high of conversion ratio, maybe <30 gallons of bio from 37 gallons of oil rather than 32-33.
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 05-30-2012, 10:13 PM
timmyboy76's Avatar
timmyboy76 seadooya
Hey Trent, i'm gonna talk to them this Saturday when i go to collect. I've seen their boxed cubies as to what they use, and its ALWAYS been 100% soybean oil. Gonna take a look because this batch was defintly not like the other 200+ gallons i've collected from them.
Me and a few buddy's think, they cleaned the grille drip or whatever, and happened to throw the meat waste into this barrell , from what i've read, the oil went into "fermenting" mode?
__________________
  #4 (permalink)
Old 05-31-2012, 06:47 AM
Rushmore X's Avatar
2003 Ford Excursion
Would like to know what caused that too. Definitely not pleasant to work with...
__________________
  #5 (permalink)
Old 06-05-2012, 10:41 AM
kirkharrod's Avatar
kirkharrod kirkharrod is offline
kirkharrod is gaining momentum as a positive member of FTE.kirkharrod is gaining momentum as a positive member of FTE.
Puke smell is indicative of bacteria growing in water in the oil. De-water the oil and then burn it!
__________________
2002 F-250 Super Cab, 289,000 miles, 89,000 on WVO; Greasecar conversion, 20 plate heat exchanger, AIH delete-water injection in its place, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, Straight Piped, GPR LED mod, CAT ELC, 203* thermostat, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, Aeroforce Interceptor scan gauge, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. No major grease related problems.
  #6 (permalink)
Old 06-05-2012, 05:06 PM
Rushmore X's Avatar
2003 Ford Excursion
Maybe that's why Hydrogenated oil seems to be worse for that smell? thanks for jumping in on that one... Would also explain the lower conversion ratio I guess...
__________________
Tags
42, ford, gas, smell, smells, tools, vomit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
