1960 f100 installing new motor/trans mounts
Old 05-31-2012, 10:52 AM
56 ford custom's Avatar
56 ford custom
56 ford custom is offline
So I am replacing all the mounts since everything is torn apart. I havent touched the truck in a while and now I cant remember how it all goes together. Can somebody please walk me through it? Here is a pic. The old on the left and new on the right. Thimk im missing the two small donuts for up front.
Old 05-31-2012, 06:40 PM
spurredon's Avatar
spurredon
spurredon is offline
Yeh, looks like you are missing the upper fronts, the old pieces that are still on your front mounting bolts.
Old 05-31-2012, 06:47 PM
56 ford custom
truck
Ok well I just boutght them a few houra ago on my lunch. So how do all of these go back together now?
Old 05-31-2012, 08:16 PM
56 ford custom
truck
Im going to try and get the motor and trans in tonight so if somebody can point me in the right direction on how exactly the bushings go in and what not. Thanks
Old 05-31-2012, 08:35 PM
spurredon's Avatar
spurredon
Well, I told you wrong on the parts you were missing. the smaller round ones that you still need are the lower fronts. The go under neath the bracket on the frame in the front of the engine. the taller round ones go above the frame bracket and below the bracket coming off the bottom of the engine. you will see how they fit into the aprox. inch hole. The bottom one fits around the top one where it sticks thru! Clear as mud yet? Then your bolt runs thru all this with a nut and washers on the top side of the engine bracket.
In the rear, the smaller rectangle piece goes on the bottom side of the big 'ol cross member. the ticker rectangle piece goes above the cross member and under the rear foot of the bell housing. If I remember right the top piece sort of stradles the cross member. Then after you put a bolt up thru a nut and washers go on top of the bellhousing foot.
I'm not much of a tech. writer but I believe I told you straight. Have fun!
Old 05-31-2012, 09:29 PM
56 ford custom
truck
Somebody has got to have some pics!! I am a visual learner lol
Old 06-02-2012, 02:07 PM
56 ford custom
truck
For the front mounts...does the bolt slide down from the top and nut on bottom or opposite way?
Glennc6
Large Truck
10-28-2018 03:16 PM
46duke
04-11-2018 06:31 AM
1962 Uni
07-12-2013 04:04 PM
Quick Reply: 1960 f100 installing new motor/trans mounts
