56 3 speed Y Block bellhousing with 3 speed transmission from 80's pickup - Ford Truck Enthusiasts Forums
Old 05-28-2012, 11:08 PM
craigibc craigibc is offline
craigibc is starting off with a positive reputation.
I have read a ton of info on this build and cannot nail down the details. I am sure you guys have seen this quite a bit so I am hoping you can point me in the right direction.
I got a 56 F100 292 Yblock and I want to replace the current 3 speed with a more modern 3 speed from a 80's pickup. I have the yblock bellhousing from the 3 speed and all accessories.
I have read you need to cut up to 3/8" off this input shaft on this transmission to get it to work with the y block bellhousing but besides that it should bolt right together?
Questions:
Is the above thoughts accurate?
What bearing, clutch pressure plate do I use with this? I have all the stuff from the yblock and it is virtually brand new.
Anything I a missing?
Any links, builds or thought would be amazing. I am posting a pic of the transmission I am using.
Thanks,
Craig
Old 05-29-2012, 11:32 AM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
The reason you cut off the input shaft is because it bottoms out in the pilot bearing on the Y-Block crank. Check before cutting.
I would use your original pressure plate and throw out bearing. Use a clutch disc that matches the spline on the new trans and the correct diameter for your pressure plate.
Is see you have duel bolt pattern on the trans so it should bolt up. Check the diameter of the front bearing housing to ensure it fits the hole in the bell.
Check trans length for drive shaft modification if needed.
Check Ford Barn or Y-Blocksforever. Someone on there may know have answers for you that I don't.
Old 05-29-2012, 11:47 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
There is another easier option. Use a model 303 Ford toploader all synchro 3 speed transmission. They were available in the 63 and 64 F100/F250. I have info here somewhere on the Jeep floor shift that replaces the original 303 top plate. Takes a little work because the side trunions need to be removed. The Jeep shifter would be centered. Since the 303s were column shift a floor shifter adapter is needed if the Jeep conversion isnt made, and it ends up left of center in the floor.
Old 05-29-2012, 11:54 AM
interesting there is so much to learn about the yblocks!
Old 06-02-2012, 03:11 PM
312 312 is offline
312 is starting off with a positive reputation.
the truck bell is deeper than the car one so you shouldnt need to grind any of the input shaft.at any rate measure.
*****HEAVY100 frame off Build Pics ***** HEAVY100 1948 - 1956 F1, F100 & Larger F-Series Trucks 79 03-10-2016 11:16 AM
80-86 parts, 92-97 parts alot BiGGreen350 Ford Truck Parts for Sale 79 10-25-2014 06:48 PM
New Towing Mirrors MustangMatt96GT 1994.5 - 1997 7.3L Power Stroke Diesel 9 02-08-2014 03:53 PM
baby blue f100 Groucho83 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-08-2012 04:30 PM
Brush Guard? MustangMatt96GT 1994.5 - 1997 7.3L Power Stroke Diesel 28 01-12-2011 05:55 AM
Tags
1980, 303, 56, 80s, adapted, bell, block, f100, ford, housing, speed, trans, transmission, transmissions, truck, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
