Hello guys, my 05 is giving me these mini shakes when I accelerate and slow down. I also get a little bit at highway speeds. I was walking around the truck today and I noticed that the back right tire doesn't have a weight on it. I thought this was wierd. Could a weight have fallen off thus causing the vibrations, or is this normal for one wheel to not have a weight?
If you want to eliminate the tires, have a road force balance done at the dealer about $65 dollars, and tell them to use the flat weights that are used on the inside of the rim, its a better precise balance than the normal, plus the computer tells which tire should go where on the truck, dont ask me how but it does
It smoothed out my truck
