1950 f-1 horn relay - Ford Truck Enthusiasts Forums
1950 f-1 horn relay
Old 05-28-2012, 06:45 PM
'49 F-1 '49 F-1 is offline
'49 F-1 is starting off with a positive reputation.
1950 f-1 horn relay
On the horn relay for a 1950 F-1 where do the wires go, there is a
H B S on the relay it self, this is 6 volt system. If anybody could help me that would be great. thanks RICH
Old 05-28-2012, 08:01 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
H goes to the horn, B goes to the Battery (or to the starter relay), S goes to the horn button switch.
Old 05-28-2012, 08:29 PM
OK thats what i thought,so witch side of batrery, the (-) side? and or witch terminal on the relay??
RICH
Old 05-28-2012, 10:22 PM
Sned66 Sned66 is offline
Sned66 is starting off with a positive reputation.
Run your relay to the side of the battery that is NOT the chassis ground. If you are running positive ground then yes you will connect to the negitive side
Old 05-28-2012, 11:31 PM
Just another Joe
Quote:
RICH
The battery connection on mine runs to the right side of my starter relay, which is the side connected to the battery negative lead, not the starter cable side. Mine is 6 volt positive ground, but that makes no difference for the way the horn relay is wired. B goes to Battery, or power, whether it's 6 or 12 volt, positive or negative ground. B does not go to ground, it goes to battery voltage. It's how the horn relay provides power to the horn(s). The horn button (Switch) provides the ground to complete the relay circuit.
Old 05-29-2012, 10:29 AM
ok i have a single horn (stock) has 2 wires coming from it, yellow & blue/orange. now from the horn relay witch wire do i connect too, and were does the other wire go (ground maybe) thanks rich
(and the horn does work)
Old 05-29-2012, 11:22 AM
petemcl's Avatar
petemcl petemcl is online now
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Some others can weigh in on this but do you really need a horn relay with a single horn? Your vehicle never had one. Of course it was 6V but still . . . it isn't like you are using your horn a lot. Or do you? A relay normally is there to provide a low amperage circuit that will reduce arcing. I'm not sure that a single horn needs it even at 12v. I subscribe to the KISS principle if at all possible. Lets see what everyone else thinks.
Attached are some wiring diagrams. Note that a wire supplies battery voltage from the circuit breaker on the back of IP to the horn. Then the wire from the horn button runs down the center of the steering column, through the firewall and out to the other horn terminal. I'm not sure if the terminals on your horn are marked but I'm not sure that it makes a big difference which wire goes to which horn terminal.
Old 05-29-2012, 08:22 PM
Just another Joe
Well, okay, that's different from my 51, which has a horn relay and two horns (5 Star Extra). I guess the 50 didn't have a relay?
So wire one side of the horn to Battery power, and the other to your horn button wire. Simple circuit with no relay. Maybe the 51 horns draw a lot more current?
1950 F-1 OEM Horns 1950FordF1 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-08-2014 03:42 PM
Horn for 1950 F 1 Barry.kroeger 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 08-30-2013 09:18 PM
Horn relay? brcwelding 1987 - 1996 F150 & Larger F-Series Trucks 2 09-30-2012 09:21 AM
1949 Horn Relay cts1954 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-20-2012 03:40 PM
6 Volt horn relay john smith jr 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 10-13-2008 11:33 AM
Tags
1950, button, f1, ford, ground, heater, horn, horns, positive, relay, test, truck, volt, wire, witch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
