Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-28-2012, 02:27 PM
EatBeef's Avatar
EatBeef EatBeef is offline
Garage is empty, add now
EatBeef is starting off with a positive reputation.
Coolant leaking badly, but none in oil
1997 f150 Sons truck. He noticed it running hot early last week and added water as it was at least two gallons low. Drove it for a couple more days and he noticed a stain under it at a friends house, added water again and drove home about 10 miles. Once home we could see a constant stream of water pouring down. The trucks been parked for a week now. Today I started searching here for answers and am confused on what i'm finding. I squeezed the upper radiator hose and it began leaking, crawled under and it appears its coming from the timing chain cover on the passenger side up by the freeze plug. Freeze plug is dry as is the water pump gasket. I drained about a quart of oil but there is no water at all in the oil. As bad as it leaks this seems wrong from what I've read. I have looked at the top of the motor and it looks dry although I haven't really dug around much on top as I'm not sure where to look. Can the timing chain cover gasket leak that badly without getting into the oil? If not where's the next place to look? Thanks in advance for any help.
__________________
2009 F250 CC 6.4
2008 Expedition Wife #1 and only
2000 F150 extended cab Son #1
1997 F150 extended cab Son #2
1952 F600 Fresh outta the pasture
  #2 (permalink)
Old 05-28-2012, 03:16 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Yes it sure can.
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 05-30-2012, 06:37 PM
EatBeef's Avatar
well,, I guess I know what I'll be doing this weekend then. O'Reilly's has the gasket kit in stock. Now all I need is the inspiration.
Thanks
__________________
2009 F250 CC 6.4
  #4 (permalink)
Old 05-31-2012, 01:10 PM
critterf1's Avatar
You mean "motivation".
__________________
  #5 (permalink)
Old 06-02-2012, 12:15 AM
EatBeef's Avatar
I told my 16 year old son, the trucks owner, to not let us stop tonight until we had the timing chain cover off, re-gasketed and back on. We got it broke loose on the top and loose at the oil pump, but it doesn't want to break free. I told him let's wait until morning and go back through everything to make sure we have everything loose. We've been following a write up from another forum and I have no reason to doubt the info, but we are working on a different year truck and some things have been slightly different, so better safe then sorry. Hopefully tomorrow things will go a little quicker. I had him go get parts today and he committed on how expensive it was. Unknown to me at the time, he had asked his Mom why we just didn't take it to a shop. I think he now has a better perspective of the cost of paying for work you can do yourself with a little knowledge, searching and time.
__________________
2009 F250 CC 6.4
Tags
302, 46, 72, coolant, expedition, f100, f150, ford, freeze, hose, oil, plugs, pouring, v6, water, wheres
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
