How to figure out what axles you have on 1977 ford highboy
What's your leaf spring count front and rear?
The VIN on the manufacture sticker matches the VIN on the plate riveted to the door which matches the VIN on the cowl tag. The GVWR matches up on the plates.
It has a low pinion D44 with open knuckles, big hubs and disc brakes up front with power assist steering. It also has the divorced transfer case.
I have 6 leaves front and rear in my springs. My frame rails measure 34" and my rear springs measure 2 1/4" which matches this info on pirate 4x4...not that it can't be wrong. I also have no rear tank, an in cab tank and two side mount tanks.
73-771/2 F250, 4wd, Highboys, Reg Cab, Super Cabs, Long Bed Frames Are Also 34" From Side To Side In The Rear. These Trucks Did Not Come With Rear Gas Tanks, Only In Cab Tanks And Side Mount Tanks If Ordered That Way. The Rear Leaf Springs Were Also 2 1/4" Wide.
1972 4x4
GVW model code
6,800 F-260
7,100 F-261
7,700 F-262
6,300 F-263
7,700 F-264
GVW model code
6,800 F-260
7,100 F-261
7,700 F-262
6,300 F-263
7,700 F-264
F260 F261 F262 F263 F264 F265 F266: 3/4 ton (4X4) (6,500–8,400 GVWR max)
I guess another explanation is that someone at the factory made a typo on the tags, but that is probably not very likely.
I have the five volume green shop manual for this truck. I am going to look through it and do some more research. I was pretty sure this was a highboy when I first bought it but now you made me second guess it. Thanks a lot...
That's why i love this forum, learn something new almost every day.
No problem, that is why I am here. This is the first Ford I have owned and I need all the info I can get on it. Now back to helping the original poster figure out his stuff.
The last LETTER and 5 #'s is the serial # which is used to identify the model year. Don't need it to see how many gas tanks u have, just look to see if there a AUX and MAIN switch to change tanks, possibly by the temp controls
Drac
12-16-2007 10:34 PM
crazy4Fords
12-16-2005 06:47 PM
Craigwell
06-29-2003 08:19 PM
