Starter Relay vs. Starter Solenoid
Old 05-29-2012, 08:59 AM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Terminology varies, depending on who is using it. For example 1948/56 Ford truck catalog sez: B6A-11450-A .. Starter Motor Relay-Solenoid Switch.
In the 1960's/70's, some FoMoCo Passenger Cars had a solenoid mounted atop the starter, no relay on the fender apron.
As I said earlier, the terminology is used incorrectly or loosely many times. I am going from terminology I learned ~ 55 years ago in electronics 101.
And you probably remember the older Ford round relays that had the mechanical "button" that could be pushed manually to make contacts across the high current contacts. Everyone called them solenoids. And technically they probably were a solenoid as the mechanical activator probably made them technically a solenoid.
A relay is a switch. A solenoid is usually defined as an electro mechanical device that produces movement of an external mechanism.
Each industry has its own terminology and the auto industry has adopted its own.
Old 05-29-2012, 09:21 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Since you seem to be older than I (67), you may recall this ditty:
You say potato, I say potatoe, you say tomato, I say tomatoe, lets call the whole thing off...
Old 11-04-2013, 10:23 PM
Real Razz's Avatar
Real Razz
Real Razz is offline
Would a 65A Starter relay be enough for a 5.8L f250 starter motor? Or would you go with a 200A relay? Trying to find a good reliable relay that is not made in China. China's quality sucks!
Old 11-04-2013, 10:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
A proper starter solenoid is likely rated at 600+ amps. Look at your battery's CCA (cold cranking amps) rating. That is the bare minimum rating I would look for. My Harley draws up to 300 CCA. If you are shopping for a "relay" online, you're looking at the wrong stuff.
Old 11-04-2013, 11:12 PM
Real Razz's Avatar
Real Razz
you are corrrect, I meant it was a starter relay, that is a big mistake on my part. But the starter relay said it was 65A so what would that mean?
Old 11-04-2013, 11:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Some cars (and for that matter, my Harley) use a relay to trigger the actual solenoid. That's done when you have a GM-style starter, where a piston-type solenoid throws the gear out into the ring gear, and closes the contacts to the starter motor. They also do it when there are other things energized only during cranking. On a motorcycle, it's done because the starter button on the handlebar has to have really small wires to fit in the handlebar loom.
Old 11-05-2013, 12:42 AM
Real Razz's Avatar
Real Razz
But the starter relay said it was 65A so what would that mean?what does it mean when a relay says it has a 65A ? Does it mean it can handle up to 65Amps or something else?
Old 11-05-2013, 07:58 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, 65 amps. That would smoke off in about half a second if you tried to energize a starter motor.
AMGrulz
11-16-2014 09:51 AM
leforrest
1997 - 2003 F150
01-24-2013 07:34 PM
ducksoup
04-05-2011 08:24 PM
TGCRVT
1983 - 2012 Ranger & B-Series
22
09-17-2010 09:03 PM
buttnuttn8
Electrical Systems/Wiring
10-22-2002 07:19 AM
Quick Reply: Starter Relay vs. Starter Solenoid
