C6 to E4OD swap - Ford Truck Enthusiasts Forums
C6 to E4OD swap
Old 05-28-2012, 11:02 AM
NavyGuy2007 NavyGuy2007 is offline
NavyGuy2007 is starting off with a positive reputation.
C6 to E4OD swap
Hey ya'll, my '89 F250 4x4 with the 460 has the C6 auto trans, which is a good trans from a reliability stand point, but not too god for the fuel mileage. I did a search but couldnt find anything, how hard of a swap would it be to change to the E4OD? I know that '89 the E4OD was an option on my truck, so in theory if I found one in a yard from a 460 4x4 would it just bolt right up and run the electronics, or is there more to it then that? Just looking for an easy way to increase the driveability of the truck. Thanks!
Old 05-28-2012, 01:27 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant future
You'll probably need a new ecu, and your wiring harness might or might not have the provisions for the E4OD. The driveshaft could be shorter (at least the rear one, but I don't recall right now) Other than that, I'm not so sure what you might be needing. Getting a 94 or newer trans is adviced, because they were upgraded then.
Old 05-28-2012, 03:21 PM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
Keep in mind the e4od is electronic controlled. And rebuilds are not cheap.
Old 05-28-2012, 07:46 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
You'll need an E4OD computer, and you'll have to add quite a few wires to the ECU connector. I also believe that the E4OD is slightly longer than a C6.
95-96-97 E4ODs are the most desirable, with the 96/97 models being more so than the 95.
Old 05-28-2012, 09:18 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
You can use a stand alone transmission controller to operate the E4OD.
E4OD using stand alone diesel TECA 4x4slik 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-18-2016 09:55 AM
e4od donor truck swap? father6 1987 - 1996 F150 & Larger F-Series Trucks 1 07-07-2015 10:48 PM
e4od to c6 trans swap vaper 1987 - 1996 F150 & Larger F-Series Trucks 10 12-05-2012 09:17 AM
Transmission Surprise, C6 not a E4od? windyhill 1987 - 1996 F150 & Larger F-Series Trucks 26 11-13-2010 07:20 PM
Will an E4OD trans from a 90's truck bolt up to a 70's 429 in a car? 1972 Ford Thunderbird 429 V8 1987 - 1996 F150 & Larger F-Series Trucks 5 10-06-2002 12:23 PM
Tags
460, 89, c6, conversion, e40d, e4od, f250, ford, increase, milage, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
