Archtaan's build thread. '10 conversion, mirrors, the works! - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 05-29-2012, 08:19 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
Quote:
Originally Posted by archtaan View Post
The originald were electric and heated. The power fold and telescope didnt come into play till 08+
do you still have them?
if so do you want to get rid of them?
my x has the hippo ears and i want to get the bigger mirrors.
They did have manual telescopic which is fine with me.
  #32
Old 05-30-2012, 02:45 AM
Sunline Fan's Avatar
Sunline Fan Sunline Fan is offline
Excursion Fleet Manager
Sunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputationSunline Fan has a superb reputation
Subscribing!
  #33
Old 05-30-2012, 10:52 AM
archtaan's Avatar
archtaan archtaan is offline
archtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputationarchtaan has a superb reputation
Update in post 3 for mirrors. Still have more to add. Will do soon.
  #34
Old 05-30-2012, 02:46 PM
lovestrucks's Avatar
lovestrucks lovestrucks is offline
lovestrucks has a very good reputation on FTE.lovestrucks has a very good reputation on FTE.lovestrucks has a very good reputation on FTE.lovestrucks has a very good reputation on FTE.
this is a great thread tim
  #35
Old 05-31-2012, 09:35 AM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Excellent stuff! Nice thread Archtaan!
  #36
Old 06-02-2012, 12:30 AM
Peace2Peep's Avatar
Peace2Peep Peace2Peep is offline
Peace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to behold
This is awesome! Maybe we could convince bushwhacker to make Fender flares for our trucks...or do they? Anywhoo, this truck is very fine indeed!
  #37
Old 06-21-2012, 06:58 PM
archtaan's Avatar
Finally got the Mag-Hytec diff cover installed.
Very easy. Unbolt the factory cover using a 1/2 socket. Clean off any gasket material and such.
Bolt the supplied hex head bolts and torque to 16 lb-ft in a criss cross pattern. Be sure to lube the o-ring with some clean fluid.
Fill with lube of your choice. I have always like Mobil1 stuff. - Don't forget the friction modifier! You need 6 bottles of lube and 2 bottles of friction modifier for this cover. It is super easy to fill too, it has a fill hole on the top.
And a drain hole on the bottom.
Check the fluid level with the supplied dipstick.
Also installed a thermocouple for the diff. temp gauge.
Be sure to recheck bolts and fluid after 25 miles.
  #38
Old 06-21-2012, 10:22 PM
I've seen those on a lot of trucks in SoCal....I haven't personally looked too much into them because was deterred by the price, but is there really a functional side to getting them instead of the "bling" look they give?
  #39
Old 06-21-2012, 10:39 PM
GIGGER's Avatar
GIGGER GIGGER is offline
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
That diff cover looks great Tim
  #40
Old 06-21-2012, 10:51 PM
archtaan's Avatar
Quote:
They are stronger than the stamped steel factory ones. Extra fluid should reduce temps, easy maintenance thats about it. I tow heavy and run hard so I am hoping to get my rear axle temps down some.
Quote:
Thanks buddy!
  #41
Old 06-21-2012, 11:12 PM
GIGGER's Avatar
Posting Legend
Extra fluid helps everytime...in anything
  #42
Old 06-22-2012, 09:29 AM
Snowseeker's Avatar
Yup, more fluid is always good. That is a great cover!
  #43
Old 06-22-2012, 03:10 PM
Quote:
Hmmm definitely have to look further into them then...you got the front and rear cover? something for me to save for once I get the lift and gears then
  #44
Old 08-03-2012, 03:02 PM
7.3 Monster's Avatar
7.3 Monster 7.3 Monster is offline
7.3 Monster is gaining momentum as a positive member of FTE.
Question
archtaan, do you remember how much it cost you to do the 2010 front end conversion? I like the 2010 more than the 2005 .
  #45
Old 08-03-2012, 03:29 PM
archtaan's Avatar
Yeah, ill shoot you a pm with totals.
Rear window trim erosion? awq134 2009 - 2014 F150 0 07-26-2016 09:07 AM
I'm back for another round.. sloar 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 03-03-2016 03:06 PM
New Member from Colorado DemonRider New Member Introductions 10 06-10-2015 11:02 AM
She Finally Arrived - 2015 F450 Stony4D 6.7L Power Stroke Diesel 38 05-19-2015 02:50 PM
Mounted a new front plate shortride 2009 - 2014 F150 7 09-24-2011 07:38 AM
Tags
2010, back, conversion, excursion, fenders, ford, front clip conversio, left, lower, mirrors, move, pain, powered, road armor, side, superduty, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
