2004 Explorer 4.0L will not turn over
Old 05-27-2012, 08:03 PM
dougsbart's Avatar
dougsbart
dougsbart is offline
Went out at lunch, NO PREVIOUS SYMPTOM, 2004 Explorer 4.0L would not turn over, just clicked. I assumed i had a dead battery. it was not a dead battery. This is what i have done:
1) Pulled battery and had load tested, tested good
2) Assumed starter, pulled and had tested, tested good
3) Checked to make sure flywheel would turn (turned one and a half revolutions w/ screwdriver and starter removed
4) Re-installed starter, pulled signal wire, hooked remote starter switch... same condition, even w/ key off (so power to starter, remote switch on hot and signal, should turn over)
5) thought maybe bad battery that did not show in load test and swapped battery, same condition
6) Assumed the only thing left was a starter that would work in test condition, but not under load-like some kind of short in windings- swapped with a NEW starter, same condition
7) Checked fuel shutoff solindoid, not tripped
8) Swapped starter relay with blower relay, same condition
9) read on posts about PCM losing memory, have tried both keys, same condition. When testing with signal wire connected (through ignition switch)
sometimes after i turn key off (since this problem) gauges flutter below "0" for several seconds. Also, i have NO security light that seems to be common with PCM memory issue.
10) Checked voltage at starter and have 13V, when key (or remote switch) attempts to turn over voltage drops to 4V at starter, immediate recovery to 13V
11) I have visually inspected wiring, i would assume a short of this magnitude would have burned wiring.
12) I guess tomorrow i will attempt to indepedently wire starter (installed) to a seperate battery and turn over w/ remote starter switch.
I am at a total loss. if the ignition switch is off, and I am using a known good battery with a remote starting switch on a NEW starter, and i know the engine is not locked up, what could cause the voltage drop and refuse to let the engine turn over?
What could have happened with no previous symptom?
Any help is greatly appreciated, I am lying in the parking lot at work...Frustrated.
Old 05-27-2012, 08:27 PM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
My friend
Basic electrics dictate you do not have a short, but rather a high resistance break..
Check the condition of the main wire from battery to starter....
Corrosion inside the plastic/rubber casing turns the copper to green sludge...Philip
Old 05-28-2012, 07:27 AM
dougsbart's Avatar
dougsbart
I will check again, but visual inspection good, general condition of the vehicle is very clean and in the south, so no salt. and I have 12V at starter and almost 0 resistance through that lead.
Old 05-28-2012, 09:29 AM
dougsbart's Avatar
dougsbart
I don't understand. New leads from known good battery to known good starter. using remote starter switch to eliminate ignition circuit, still will not turn engine over? Engine not locked up, i can turn from flywheel with a screwdriver?? Is there something that locks engine from turning over? I have never been this stumpted? I cannot believe I am going to call the tow truck.
Old 05-28-2012, 11:25 AM
aquanaut20's Avatar
aquanaut20
If jumper-ed hot from B+ to main starter terminal and no spin, you need to check the ground return to the battery.... Philip
Old 08-20-2013, 07:16 AM
Diydarnell's Avatar
Diydarnell
Diydarnell is offline
Solution?
Dougsbart - any chance you found a resolution for this issue?? I have the exact same issue with my 04 Explorer. Unfortunately I am 52 miles from my uncle's shop. I've tested the battery and solenoid, but they are working well. I'm reading a lot about the wires to the starter being corroded or burned through. Today I will get under the truck to check that.
But if you have a solution to your problem, I'd love to hear it.
thanks!
DiscardedFrog66
09-25-2019 09:28 AM
Aeroman59
Aerostar
11-02-2007 08:30 PM
websthes
10-03-2005 04:01 PM
GSchretter
09-02-2004 01:45 PM
CRJ900
17
02-02-2002 10:22 PM
Quick Reply: 2004 Explorer 4.0L will not turn over
