Best Injectors
#46
The first three: Fumoto valves because pulling the block plugs makes doing the chem flushes faster and easier, and so you only have to pull the starter once. The pressure regulator is just the blue spring part of what everyone calls "the blue spring mod", you don't have to buy a kit with a replacement cover, check at RiffRaff for the the cheaper kit. I always reccommend the updated HFCM plug because mine was already corroding on an '07, some guys have this problem and some don't, plus the update lets you drain the water separator without any tools.
Riffraff Diesel: Ford Fuel Pressure Regulator Blue Spring Kit
Standpipes connect the oil rail the the branch tube in the block. They're prone to leaking, so when you pull the oil rails as part of removing the heads, you replace the standpipes. Your '03 should have the original rails, so you don't need the dummy plugs.
Ford Truck Enthusiasts Forums - texastech_diesel's Album: Junk - Picture
You'll need a turbo install kit, and you should search about updating the oil feed line for the turbo because you might have the old braided line that will need to be replaced.
I just changed my coolant so i dont want to do a flush... and I dont think ill do a chem flush so do you think I should still do all of this
#47
whats the advantage of this Riffraff Diesel: Sinister Basic EGR Cooler Delete Kit over this BulletProof EGR Cooler, Round
#50
#51
What is the ECT/EOT split? If you need to replace the oil cooler, doing a real good restore and restore+ flush is going to make the new cooler last a lot longer. If you're on the original oil cooler I'd flush it out no matter what the delta before the tear down and go ahead and replace the oil cooler because you'll be in that deep, but if you want to try to string your old coolers along that's your call. Just in general, anytime you replace the oil cooler, you absolutely need to do a chem flush.
#52
#53
I dont want a lot of power but if I turn the tuner up that'll only be for a short amount of time and I don't plan on a turbo unless I have to
#54
I would clean the **** out of it if you know you'll be replacing the oil cooler. No need to let some leftover junk wreck the new cooler. I guess if you just chem flushed recently it you could skip it, but if you just flushed with water to swapthe coolant out then yes, I'd use restore on it.
#55
I don't have a eto gauge
#56
#57
#59
#60
The cooler is removed, and those parts basic keep the coolant flowing. If your worried about smog/emissions visual testing...do not use this. A reasonablely trained inspector will know your EGR system is not there.The cooler remains, and is basically what the '03 engines had from Indianapolis or Huntsville when they were shipped to KTP.
