Clicking noise in front end - Ford Truck Enthusiasts Forums
Old 05-27-2012, 03:40 PM
soling2003 soling2003 is offline
soling2003 is starting off with a positive reputation.
FWIW....I had this clicking noise coming from the right front tire on my truck in my sig. Sounded just like a rock in the tread, which happens a lot, and we had just driven on a gravel road. I got rid of all the rocks and it was still there. But you could only hear it with the front passenger window open. Barely when the rear pass. Window open, and pretty much only if there was some kind of wall or hedge on the right side of the road for the sound to bounce off of.
It changed with speed, but not on braking or turning.
So I searched on here last night and found a bunch of good info. So today I drove to make sure it was warmed up and it made the noise and jacked up the front. Tire was solid, 4x4 hubs when in and out fine, brakes not scored, and no noise! I tried spinning it as fast as I could....nothing. So let it back down and I'm not 20 ft and there is the clicking noise! Back to driveway and remove the tire. There is a very faint noise from the hub where bearings are, but no clicking of any kind anywhere. So I put a little lube on the matting surface of the hub to tire, remount it ( the lug nuts weren't as tight as I might have thought), torqued em down and viola, no more noise! Seems the wheel was moving ever so slightly on the hub as it rotated. It needed the 2500 pounds of weight on it to move.
Sorry for the long winded post, but just one more little thing to look at when diagnosing sounds on these heavy trucks. I only have 14,500 miles on this, so couldn't believe it would have been anything actually wearing out yet, as was relieved.
Old 05-28-2012, 12:52 AM
marchare011's Avatar
marchare011 marchare011 is offline
marchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant future
Glad you found the problem.
Sucks that you had too. Was that the original location of that tire and wheel or have you rotated the tires?
Good place for a reminder: Always retorque the lugnuts after removing a wheel.
Old 05-28-2012, 03:20 AM
I have the service contract, so dealer does it every 5000 mi when I get the oil changed. So no, it isn't the original position.
Old 05-28-2012, 11:28 AM
PITS's Avatar
PITS PITS is offline
PITS is gaining momentum as a positive member of FTE.PITS is gaining momentum as a positive member of FTE.
I found when I picked up my truck, brand new ordered from factory, not one lug nut was to torque spec. I assume that is on the dealer's pre-delivery checklist but must have got skipped. Some of the nuts were only finger tight.
Popping & clicking noise in front end jeepfix 1997-2006 Expedition & Navigator 6 08-22-2015 10:18 AM
Clicking from Left Front End Superred2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 06-28-2011 11:41 PM
F250 with clicking noise in front end tarrin1859 1999 to 2016 Super Duty 3 04-26-2011 04:18 PM
rock tumbler with hubs locked? akorcovelos 1999 to 2016 Super Duty 35 02-01-2011 06:08 PM
2001 SD, front diff. problems BroncoPimp94 1999 to 2016 Super Duty 2 02-09-2010 07:45 PM
Tags
2005, 4x4, 60, clicking, end, escape, f150, ford, front, hybrid, noise, sound, ticking, tire, tires, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
