The best spray on bed liner
got Rhino on my truck in Feb of 2005 after i bought my truck, its holding up great to the repeated topsoil, mulch, dirtbikes, atv, wood, etc over the years. It hasnt faded yet i wash it with SprayNine and a scrub brush. I will say this it statred to pop around the bed bolts for some reason and inoticed last week that a section under the bed rail is starting to peel when they stopped spraying it, some superglue was all the added to make it stick again?
If you're doing a clean install, Line-X is the best going. If you're replacing or repairing an old one, I'd use herculiner or rhino and try to patch it, but you could call a line-x installer and ask how they get rid the the old liner. Black RTV is a quick patch for a cracked or peeling section, I have bad luck with nails stuck in fence panels scratching all the way through.
I've used herculiner before and it was ok but did not hold up to sun damage. I have a Rhino liner in my new truck and it is much better. One thing I have noticed with any liner is that being black they are very prone to fading and UV damage if left exposed. I keep a tonnea cover on mine now and it is holding up much better.
i do the same thing, shovel and rake dirt, mulch out of my bed and the Rhino still looks brand spankin new. I wont throw a 50lb chunk of steel in the bed though, it will still bend and dent the floor......
Another vote for LineX. I had my 05 done when new and it's holding up pretty well. It has a few good blems from getting whacked by bobcat attachments, careless handling of chain binders, sheets of plywood, etc. I've had it patched before and need to have it patched in a few areas again, but compared to a drop in, it's far superior. Hurculiner is an OK DIY liner, but won't hold up like LineX. I've used hurculiner a lot for a home-made trailer, flatbed, plow mounts, bumpers, bottom of the doors, etc and it works good for those applications where it just doesn't make sense to pay the premium for LineX. I've also used the duplicolor spray can stuff on the bumper and grille guard of my F550, and it's holding up well (they were sandblasted and primed first), but have also used it on a few other things and it didn't last much longer than rust-oleum would have (prep is the key).
Here's a pic of the F550 with the duplicolor spray-on on the grille guard and bumper and hurculiner on the rockers, door sills, and bottom of the doors, taken right after putting the hurculiner on. The door sills being a fairly high wear area getting in and out and subject to all the road spray and rocks off the front tires, I applied the herculiner all the way up to the bottom gasket inside the door opening. The herculiner worked so well for this I'm doing it on 2 more trucks this summer. But for a truck bed, I'd still do LineX over herculiner.
Also, a pic of the F350 Flatbed. We built this bed ourselves and coated all the steel for the flatbed, rear bumper, mud flap brackets, and hitch with hurculiner. It looks more gray as it fades in the sun, but it seems to hold up fairly well.
A general question...
how much weight does a liner add to your rear axle weight ? 50 lbs? 100 lbs ?????
Since I have a 5th wheel hitch and a tonno-pro cover it's not like it's not protected from the elements, but considering a spray in just the same...just don't want to eat into my payload
That reminds me, I need to clean the pop cans and extra glass clippings out of my bed, they're eating into my payload...
