Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 05-27-2012, 07:30 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
Talking Happy with Gear Ratio swap
Yesterday my son and I did something I have wanted to do for some time. We replaced the 9" rear 3.7:1 differential with a 3:00:1 differential. I was a little concerned about the big change and how the truck would perform.
Since many of you are new, my truck has a rebuilt 292 with ECZ-C heads (bigger valves), 4 bbl Edlebrock street carb, an improved street cam from John Mummert and dual ram horn exhaust. Estimated HP is about 210 (the original was 175hp if I remember correctly). I figured with the few extra horses, we could change the ratio without to much loss of performance.
Results: I now have a true 4 speed (T98). The granny gear is actually a usable gear now. In fact starting out in first takes the truck to nearly 20 mph. 35 mph is easily achieved in 2nd and you can cruse at 45 mph in 3rd at only about 2500 RPM's. Now the best part, on the highway cruising at 65 MP is achieved at 2800 RPM, it was about 4000 RPM's with the 3.7 and the engine noise was quite loud. Now you can go 65+ and conversation and listening to the radio is quite easy. I am sure gas mileage is improved.
All-in-all I am quite happy and so is the truck, so I thought I would share the good results.
__________________
Walston
http://bigjohnstractor.com/
  #2 (permalink)
Old 05-27-2012, 02:36 PM
spurredon's Avatar
spurredon spurredon is offline
Garage is empty, add now
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Sounds pretty cool. Did you change the gears or did you swap out the third member?
  #3 (permalink)
Old 05-27-2012, 03:27 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is online now
theodore/teddy is starting off with a positive reputation.
Walston 2800 should be a happy spot for your Y-block.
Now your all set for a run down to Docstock or Truckstock in Kentucky.
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #4 (permalink)
Old 05-27-2012, 04:33 PM
Walston's Avatar
1960 Ford F-100
Quote:
I swapped the entire third member.
__________________
Walston
  #5 (permalink)
Old 05-27-2012, 04:34 PM
Walston's Avatar
1960 Ford F-100
Very true. From one Wally to another.......
__________________
Walston
  #6 (permalink)
Old 05-28-2012, 01:13 AM
sm7482's Avatar
sm7482 sm7482 is offline
sm7482 is starting off with a positive reputation.
Nice!!! i have a dana 60 in mine. it was a ranch truck and is geared so low first only gets you to 5mph, 2nd to 20, 3rd to 30, and 4th tops out at 50. i can hit 60, but it turns at 2500 when im going 40 so imagine 60!!! Finding parts on a budget for the dana 60 is, tough I have a friend with a 58 f100 with a 9" in it. he's running 2.somethings and his tach reads 2000 at 60-65 with the 4speed. wouldnt that be nice? Anyway, i'm jelous of your gear swap!! my truck doesnt even have any sound insulation!
  #7 (permalink)
Old 05-28-2012, 06:12 PM
spurredon's Avatar
Quote:
some trucks do have insulation?
  #8 (permalink)
Old 05-29-2012, 07:48 PM
sm7482's Avatar
well, alot of people install sound deadener to the floors ceiling etc, to quiet the road and exhaust nan noise. the trucks also came with an asphault type insulator between the firewall and inside of the cab to reduce engine noice. Well, my truck has 0 sound deadener covering the floors, ceilings, doors etc and i tore out all the asphault insulation between the firewall and inside of the cab so you hear all the motor noise. I also have no headliner so the cab turns every vibration into sound which gets very VERY loud haha. Oh, and i have no mufflers, just straight pipe, with a 4.56 rear end. so just doing 50 at 3000 rpm gets old real fast i am investing in lower gears and sound deadening mats very soon!
  #9 (permalink)
Old 05-29-2012, 07:50 PM
sm7482's Avatar
maybe mufflers too, but i like the sound
  #10 (permalink)
Old 05-29-2012, 07:56 PM
fast58's Avatar
fast58 fast58 is offline
fast58 is starting off with a positive reputation.
Kyle Brazier
How about cut outs so you can have noise when you want it and quiet when you don't.
__________________
http://www.ford-trucks.com/forums/im...ine=1324186537
1958 Ford F-100. 351 W .030 over and Speed Pro flat top pistons, Comp Cams 224/226, World Windsor Sr. heads, Edelbrock Performer intake, Holley 750 carb, Roller rocker arms, Proform one-wire distributor, MSD 6-AL ignition.
  #11 (permalink)
Old 05-30-2012, 12:23 PM
FJones8668 FJones8668 is offline
1959 Ford F-250
FJones8668 is starting off with a positive reputation.
What size tires are you running? I have been thinking about a gearing swap just like that when i finish installing my T-98! I have a hunch that my tires may be taller than yours though so I'll have to take that into consideration.
  #12 (permalink)
Old 05-31-2012, 04:38 AM
THartman THartman is offline
THartman is starting off with a positive reputation.
Great results with the gearing.
  #13 (permalink)
Old 05-31-2012, 05:00 AM
Walston's Avatar
1960 Ford F-100
Quote:
P235 75 R15
Good luck
__________________
Walston
Tags
1959, f100, ford, gear, ratio, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
