'63 F100 won't start, trying to find casting number.
No Biggie, Chris....really. No one is going to fault a guy for being busy or holding a job!
The country needs more like folks like you!
I was in the neighborhood and just thought I'd poke my head in to inquire...and you, heck, nobody should feel like they need to get in a RUSH over these ol' buckets of bolts - these ol' relics should provide an escape from the day-to-day drum & are to be enjoyed - not turned into just being ANOTHER JOB!
I'll check back Sunday evening - Stay Loose...
BarnieTrk
BarnieTrk
All you have to do is pull a sparkplug and insert a straw or similar to measure the depth of the stroke at the bottom. So, go pull a sparkplug, turn the engine over slowly with a socket wrench on the crank dampener nut until the straw has stopped going down. Mark the straw with a marker pen & measure the straw length.... and compare it to:
BarnieTrk
Well we got the truck running again after some time and a few extra parts...
I replaced the spark plugs and the wires I broke in the process because the engine was past due...
Still didn't start but I figured that would happen...
Then we replaced the ignition control module because we were told that those typically are the first to go. Still didn't start...
So we decided how the distributor was and took that out. The inside was pretty bad and a couple teeth were broken on the gear in the process... New distributor was bought and installed. Still didn't start. Crap.
The coil is what we originally wanted to change first but were told not to. So we went ahead and bought a new one and as we are taking off the old one realize that the wire going into the coil was not pressed in all the way to "click" into place...
We replaced the coil anyways when all we had to do was check the wires.....
