How do I remove just the glass from door mirror - Ford Truck Enthusiasts Forums
Old 05-26-2012, 09:51 AM
reamer's Avatar
reamer reamer is offline
reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.
Pass side door mirror glass is cracked, How do I remove just the plate glass, (not the whole assembly) are there pins or is it glued?
Thanks
Reamer
Old 05-26-2012, 01:51 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
tilt the glass so it's pointing to the sky
take a narrow flathead screwdriver and a flashlight
looking from the bottom of the casing into the gap, look for a 1/4" gap near the center. push the screwdriver in there and the glass should pop right out.
I'd warn you to be careful, but you already broke yours. I snapped mine being stupid before I learned about that slot
2003 outside mirror GLASS replacement Supercab Ranger & B-Series 6 11-11-2015 07:41 AM
56 door windows Rogers F100 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-25-2014 05:19 PM
Door Mirror Glass Replacement johnmel59 1961 - 1966 F-100 & Larger F-Series Trucks 4 12-18-2013 04:57 PM
2003 Exp side power mirrors not operating stevebigos Expedition & Navigator 3 06-22-2013 06:41 AM
Hmmmm... what size bushing reamer to use reamer 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-16-2005 02:30 PM
Tags
2002, f150, glass, mirror, side
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
