brake squeal - Ford Truck Enthusiasts Forums
brake squeal
Old 05-26-2012, 01:36 AM
tasboj's Avatar
tasboj tasboj is offline
tasboj is starting off with a positive reputation.
brake squeal
Hi guys I have a 1970 ford f 250 ranger xlt and i just changed new rotors,pads,bolt pins and brake hardware kit and my brakes squeal like crazy it is driving me nuts i don t now what to do does anybody have any suggestions what to do so i can fix this noise any help would be appreciated thank you
Old 05-26-2012, 12:13 PM
willowbilly3 willowbilly3 is offline
willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.
Disc brake squeal is almost always caused by pads that are loose in the holders. Did you install the anti-rattle springs new?
Oh, and that anti squeal goop in a bottle, it's made for the mechanic not for the brakes. It does nothing to quiet noisy brakes, just makes you think you're doing something.
Old 05-27-2012, 01:14 AM
tasboj's Avatar
Thanks for the reply willowbily3 I already fix the problem, I took everything apart put new bolt pins, new springs and bushings turn the rotors and I put some of the anti squeal goop your talking about and the noise is gone. Now I'm not saying that the goop fix the problem and I will never now because the first time I installed all new rotors,pads,springs,bolt pins,bushings except the goop and the brakes squealed very loud. but a friend did tell me to drive the truck at 35mph and hit the brakes soft until I slow down to 5mph I did this tree times and then did the same thing but this time at 45mph and slow down to 5mph tree times, He said this is to transfer a layer of pad material to the disc and thats what makes the pads grip to the rotor anyways it worked the squeal is gone. Now I can drive down the road and not be emberest to hit the brakes and have people stair at me.
Old 05-29-2012, 06:20 AM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
The magic goo is basically a plastic flexible glue to insulate the steel face of the pad from the steel piston & caliper. You may have burned off the noise but as said it is usually caused by a pad that is moving around. Small foreign brakes were real bad about it which is where I first was introduced to the product (EMP). Just info for you to have in the future. Burning the pads in doesn't hurt either. I assume you cleaned the packing oiol off of the rotors prior to installation.
Old 05-31-2012, 02:05 AM
tasboj's Avatar
elgemcdlf thank's for the info the problem has bean solved, but yes I did clean the packing oil with break cleaner so far so good no squeal at all.
Random brake squeal 7283-F250 Brakes, Steering, Suspension, Tires, & Wheels 1 07-06-2014 12:08 PM
squealing noise is driving me crazy twall_SD250 1999 to 2016 Super Duty 8 08-19-2011 09:31 AM
What is causing the squeal from the undercarriage??? sa_rains Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 12-04-2005 12:39 AM
brake squeal Matthew Henson 2004 - 2008 F150 18 09-15-2005 09:43 PM
Brakes JWMBK 1999 to 2016 Super Duty 13 08-05-2003 08:22 AM
Tags
2007, brake, disc, expedition, squeal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
