Sorry if posted before. Purchased the Lisle Tool fuel line removers (angled plastic).
Try as I might, I cannot make this work. Trying to remove water separator cover & replace (bought the Ford kit, minus sensor). I understand the concept, am inserting the tool & push into the fitting and pull on the line - nothing.
I would appreciate any ideas. Thinking of trying the dealer in the morning. Sick & tired of draining water separator - and the fuel never settles out into water & fuel, just fuel.
If you can indicate how I should put the parts in post from 6:37 pm yesterday, I think I will be good to go. I don't think the black one came from inside, but can't be sure. Fell off when I was pulling the cover off & hoses off the cover.
You bought the gasket kit from Ford before you did this, correct? The service bulletin I read (that was linked from here) said that was necessary as they would likely leak if reused...
If you are careful, you can reuse the manifold gasket. Most of the time it is so deformed it isn't reusable.
