cruise control not working
I have read some post on this but was unable to get mine working. I have an 01 with the 6 speed. I had just put in the speedwizard to change my speedo for my 37's. I ran the truck down the road with cruise on to set the box and it worked fine. Then i went back home put the speedwizard on some Velcro and attached under the steering column and zip tired the wires up and out of the way. Put the cover back on and now i got no cruise control. So i tested the horn after reading about the spring and my horn works fine every time and the lights light up on the steering wheel. Then i tried starting the truck with out pushing in the clutch and it wouldnt start. I have my trailer behind my truck and the trailer brakes are working fine so i assume its not the brakes sensor kicking in. Is there a double part to the clutch switch that might be bad where it kills my cruise but not the no start? Thanks
J5BAIL
07-19-2013 02:14 PM
Yougotthehit
27
11-16-2011 10:46 AM
