cruise control not working - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-25-2012, 07:24 PM
rockcrawler_101 rockcrawler_101 is offline
rockcrawler_101 is gaining momentum as a positive member of FTE.rockcrawler_101 is gaining momentum as a positive member of FTE.
I have read some post on this but was unable to get mine working. I have an 01 with the 6 speed. I had just put in the speedwizard to change my speedo for my 37's. I ran the truck down the road with cruise on to set the box and it worked fine. Then i went back home put the speedwizard on some Velcro and attached under the steering column and zip tired the wires up and out of the way. Put the cover back on and now i got no cruise control. So i tested the horn after reading about the spring and my horn works fine every time and the lights light up on the steering wheel. Then i tried starting the truck with out pushing in the clutch and it wouldnt start. I have my trailer behind my truck and the trailer brakes are working fine so i assume its not the brakes sensor kicking in. Is there a double part to the clutch switch that might be bad where it kills my cruise but not the no start? Thanks
Old 05-25-2012, 09:22 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
If the springs are broken inside the clutch position switch, then yes it can kill the cruise and still not start unless the clutch is pushed in. Pull the CPP off and take a look at the springs. That should tell you all you need to know.
Old 05-26-2012, 01:32 AM
i pulled it off and it looks ok. Here are two pics of it. Its got an electrical brass piece that seems like its not allowing the spring to go all the way forward. is this right
Old 05-26-2012, 07:46 AM
F350-6's Avatar
What does the other half of the sensor look like? The part with the springs in it?
Here's one of mine with bad springs.
Old 05-26-2012, 11:38 AM
Both springs look good. I do get a compleat cercit between two of the connectors in the middle of the plug. Im assuming that this is not my problem but it is somewhere else.
No cruise control, "something behind the steering wheel" Golden Helmet 1987 - 1996 F150 & Larger F-Series Trucks 8 01-31-2014 04:52 AM
yet another cruise control thread 3cv Excursion - King of SUVs 18 03-10-2013 09:59 PM
Pressing Cruise button blows horn!?? vwhed1979 Aerostar 3 01-20-2006 12:24 PM
Horn/Cruise control fuse keeps blowing Mr. Whiskers Electrical Systems/Wiring 2 01-10-2004 09:26 PM
Horn / Cruise Connections yorxs 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-04-2003 11:41 PM
Tags
1996, 2009, 250, 64, 73, comtrol, control, cruise, diesel, f150, f350, ford, springs, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
