Your VGT% at Hot Idle? - Ford Truck Enthusiasts Forums
View Poll Results: What is your VGT% at Hot Idle? (please vote)
pegs at 85% 8 44.44%
80-84% fluctuating 1 5.56%
77-80% 3 16.67%
70-76% 6 33.33%
I haven't a clue, I have no gauges. 2 11.11%
What the heck is VGT%? 2 11.11%
I don't do polls. 2 11.11%
Multiple Choice Poll. Voters: 18. You may not vote on this poll
Old 05-25-2012, 12:26 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
So, what does your VGT% show at hot idle? And what determines the VGT%?
I have been told my VGT% is too high at hot Idle. Mine still, even after new turbo, pegs at 85% at hot idle.
Also, which sensors are used to determine the VGT%?
My EBP at hot idle is 16.8.
Any other sensors I need to be checking that effects VGT%?
Old 05-25-2012, 01:14 PM
bubba_78363 bubba_78363 is offline
bubba_78363 is gaining momentum as a positive member of FTE.
Sean mine does the same thing. Originally thought it was because the veins were sticking, but even after cleaning the turbo it still sits right there at the max. Haven't noticed any ill effects from it either. I had read before that you should never see 85, but I dunno. Reading is taken off Scan Gauge.
Old 05-25-2012, 06:20 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
hot idle iirc should be 85%
Old 05-25-2012, 06:53 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
well the Operating Value calls 73% at Hot Idel
VGTDC # 0 73 43 0 - 100 PERCENT Turbo Duty Cycle
IIRC mines right in that 68-73%
I will go for a ride here in a Minute and check and cast my Vote Sean
Does it Idel Bad or Just the Number seams Off???
I remember going threw this awhile Back seemed like folks was hiting in 60s-80s IIRC
Old 05-25-2012, 07:04 PM
Those are the values I show. 73% low idle hot.
Old 05-25-2012, 07:09 PM
BLADE35's Avatar
Quote:
Originally Posted by amdriven2liv View Post
S
MAF & BARO & MAP
Im shure your checkkiing at KOEO
But also need to watch as you drive to for erratic readings and stuff like that
Old 05-25-2012, 07:23 PM
white04kr white04kr is offline
white04kr is starting off with a positive reputation.
66-67vgt. 184wt 187eot low idle with ac on.
Old 05-25-2012, 07:47 PM
BLADE35's Avatar
At Hot Idel ECT 190*+ VGT% was 60% and 15% when Veins Sweep
Hot Idel In Gear but stopped VGT% was 60%
I didnt see 60% VGT so I couldnt vote Sean it was out of my range to
Also 60% VGT was Steady at Idel AS long as the veins didnt sweep
Old 05-25-2012, 08:48 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Okay, I'll bite.
On mine, at about 195*F at idle in PARK, EBP_A reads between 16.8 and 17.0 psi. MGP reads between 0.36 to 0.39 psi. My VGT duty cycle remains steady at 68 %. Since the range of duty cycles you posted, is out of my range, I couldn't vote.
Does this information help?
Old 05-25-2012, 09:08 PM
BLADE35's Avatar
Mike can you tell me/us about MGP or Manifold Gauge Pressure
Is it the same as Boost psi or MAP Minus Baro pressure reading???
What is it I tried to research it alittle the other day and didnt find a answer
The real reason I wanted to know what MGP is was because I was going to try and see if James D (He is the Guy at ScanGauge Company that writes the Codes we Need/want to monitor the PID) Could give us a Code to monitor it with our ScanGaugeII Units
Thanks again Mike
Old 05-25-2012, 09:14 PM
Roasted7's Avatar
Roasted7 Roasted7 is offline
Roasted7 is gaining momentum as a positive member of FTE.
62% at 190 eot
Old 05-25-2012, 11:22 PM
m-chan68's Avatar
Thanks again Mike
Yes sir!!! You are correct!!! MGP is the actual boost pressure.
Old 05-26-2012, 12:29 AM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is offline
Frankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to all
Mine runs around 55% or so.
If everyone else is reading 75-85%, that could be a HYOOGE explanation of why mine won't get out of it's own way trying to come out of a stoplight.
The only time mine is at anything over 75% is at cold startup, and only stays there for a couple of minutes.
It's normal operating range is anywhere from 45% to 65% normally.
Since it's counter-intuitive, here's a little explanation here of how the VGT% works; it's a number that represents the duty cycle of the VGT solenoid. 85% duty cycle equates to the solenoid being fully extended, which closes down the vanes to their tightest configuration. Conversely, 15% duty cycle on the solenoid opens the vanes fully, allowing maximum gas flow towards the turbine wheel.
Keeping the vanes closed (or nearly so) at idle and low engine speeds mimics a tiny turbo that spools quickly and provides little lag. Opening the vanes as engine speed and load rises allows the turbo to act as a larger unit, which is able to produce larger boost flow as the engine requirements increase, without overspeeding a smaller unit, which would result in both overboost and turbine explosive failure over time.
(Also, in the emissions world, closing the vanes down under certain operating conditions provides the back pressure necessary to force exhaust gas through the EGR cooler and into the positive-pressure intake manifold.)
-blaine
Old 05-26-2012, 03:56 AM
Benny, KOEO readings. MFv is MAF volts.
Old 05-26-2012, 04:17 AM
I think this is getting interesting. Where would the best VGT% be then? Ford says normal is 73% low hot idle.
As Frankenbiker shared, the way the vanes work, the higher the VGT%, the better off the line? And lower would make the truck work more to get moving. So, what would be the answer to getting the VGT% to the best spot. Ford's 73%?
__________________________________________________ ________________________
Here are some videos I took on the drive home tonight. The first 2 are doing 60 mph pretty level ground, cruise set. MFV is MAF volts. See anything odd in these? Let me know.
Xgauge reading - YouTube
Gauges - YouTube
The 3rd one is coming to a stop, then taking off. I didn't get a good full screen shot, but the 2 gauges on the right are: top right EBP, bottom right MFv.
Xgauge again - YouTube
VGT % at idle? Restlesswildman 6.0L Power Stroke Diesel 3 07-18-2015 04:15 AM
VGT % rattleNsmoke 6.0L Power Stroke Diesel 7 05-11-2013 01:21 PM
VGT Readings mmenzies 6.0L Power Stroke Diesel 7 10-24-2012 08:05 PM
P0299, EBP, VGT values...deciphering help requested. f150crewcab Excursion - King of SUVs 1 06-05-2012 08:54 PM
VGT readings on scangauge j4henry 6.0L Power Stroke Diesel 22 04-17-2012 10:51 PM
Tags
0, 85, cycle, f350, ford, hot, idle, idling, made, mpg, readings, results, scangauge, shows, truck, tune, vgt, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
