Your VGT% at Hot Idle? - Page 3 - Ford Truck Enthusiasts Forums
View Poll Results: What is your VGT% at Hot Idle? (please vote)
pegs at 85% 8 44.44%
80-84% fluctuating 1 5.56%
77-80% 3 16.67%
70-76% 6 33.33%
I haven't a clue, I have no gauges. 2 11.11%
What the heck is VGT%? 2 11.11%
I don't do polls. 2 11.11%
Multiple Choice Poll. Voters: 18. You may not vote on this poll
  #31
Old 05-27-2012, 09:07 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is online now
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Thanks you guys for your input and thoughts. I'm going to keep looking at things. Might try to convince the CFO for funds for an AE. Look a little deeper at things. (hard after the turbo funds)
I'll keep watching things and see if anything changes.
  #32
Old 05-27-2012, 09:24 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Quote:
Originally Posted by amdriven2liv View Post
. Might try to convince the CFO for funds for an AE. Look a little deeper at things. .
LMAO Good Luck Sean
  #33
Old 01-14-2013, 09:11 PM
elwooda1a elwooda1a is offline
elwooda1a is starting off with a positive reputation.
Thread resurrection.
Hello all. I have been reading many threads on the subject of low power/possible turbo problems and this one seems to fit my problem quite well. I hope your willing to help.
Well, let the hijacking begin:
2003 f250 6.0. Reg cab. Reg bed. XLT FX4 Stock everything. Original owner. 135K miles. Was in the shop once for ball joints n 2008 and once again in 2010 for ICP and ?pigtail?
Last month I heard a pretty good exhaust leak behind the turbo and after reading a bunch here and sticking my hand back there i realized my y pipe had the ever popular gash in the flex joint. I decided to tackle it myself. Pulled turbo, pulled y-pipe, installed new y-pipe, re-installed turbo, checked for exhaust leaks. All good.
My problem is that my lack of power that I thought was from this massive exhaust leak before the turbo, is still present.
So I took the forum advice and bought a scanguage II and began the mind blowing do it yourself diagnosis.
FICM VOLTAGE= all ok
MAP and BAR = ok (ebp was disabled by ford with some reflash)
VGT is constantly stuck at 85% at idle and while driving!
Egr desired reads anywhere from 4 to 45 but EGR is always zero unless I unplug it then it reads 100. Doesn't move while driving in either state.
BST seems surprisingly normal considering I have zero power? Gets up to around 24 if I push it.
The strange thing is The LOD (engine load at idle is 30 then gets up around 70 sometimes while driving.
Recently EOT has been about 12 degrees higher than water temp.
And finally my question! Does this jive with a stuck turbo unison ring or is it something that's prompting the truck into thinking it needs to be at 85% all the time.? Or a bad vgt solenoid?
I hope I'm making sense and hopefully I'm typing all this in an ok spot
Thanks
Mike
  #34
Old 01-16-2013, 06:51 AM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
mine is somewhere between 65-70%
VGT % at idle? Restlesswildman 6.0L Power Stroke Diesel 3 07-18-2015 04:15 AM
VGT % rattleNsmoke 6.0L Power Stroke Diesel 7 05-11-2013 01:21 PM
VGT Readings mmenzies 6.0L Power Stroke Diesel 7 10-24-2012 08:05 PM
P0299, EBP, VGT values...deciphering help requested. f150crewcab Excursion - King of SUVs 1 06-05-2012 08:54 PM
VGT readings on scangauge j4henry 6.0L Power Stroke Diesel 22 04-17-2012 10:51 PM
Tags
0, 85, cycle, f350, ford, hot, idle, idling, made, mpg, readings, results, scangauge, shows, truck, tune, vgt, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
