I NEED HELP WITH MY 1968 F 850!!
I have a 1968 f 850 superduty. I am in need of a left and right front front spring bracket. It has a 7000 lb front axle according to the tag on the door. however it has a Marmon Herrington front axle. Anybody out there that may have an idea to where I can locate them??? Any help is greatly appreciated!!!
The problem is, you have a Marmon-Herrington 4WD conversion. So will the following parts be correct...or not?
C1TT-5340-D .. Right Front Spring FRONT Bracket / Obsolete
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
C1TT-5341-A .. Left Front Spring FRONT Bracket / Obsolete
Could not find any. Try BIG truck specialist Job Lot (joblotauto.com) located in Queens NY.
Help with my 68 f 850
Can you see if I am correct with these part numbers for the rear rear spring bracket? The right side has it stamped c3ta 5894G and the left side has c3ta 5928G or the 8 is a 9 I cant tell. Thanks for your help!
Kyle
Kyle
Welcome to FTE
From the 1948/66 Ford Master Cross Reference Catalog & the 1957/63 & 1964/72 Ford Truck Parts Catalogs:
Applications for the following: 1963/69: F800/1000 (reinforced frame) & F1100 (standard frame).
Marked: C3TA-5894-G = Ford part number: C3TZ-5775-AK .. Right Rear Spring REAR Shackle Bracket / Obsolete
Marked: C3TA-5929-G = Ford part number: C3TZ-5775-AJ .. Left Rear Spring REAR Shackle Bracket / Obsolete
GREEN SALES CO. has TWO.
Could not find these two parts anywhere else. I used my Master Cross Reference Catalog to cross these Ford ID numbers over to Ford part numbers.
GJCAT
06-11-2019 08:56 AM
jimbo beam
04-03-2014 05:32 PM
flipklos
04-21-2010 08:26 PM
stil190
02-22-2010 04:23 AM
