HELP AGAIN
Old 05-27-2012, 02:19 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
Originally Posted by Regulator1988
I've replaced it already. That was in park though
Oh I thiught you was driving it
Back to the VGT or Massive leak
what kinda Boost do you see driving it
  #62
Old 05-27-2012, 02:22 PM
BLADE35's Avatar
BLADE35
Looks like the tuner turned up is masking the problem to a point
  #63
Old 05-27-2012, 02:29 PM
Regulator1988's Avatar
Regulator1988
Regulator1988 is offline
So I need to take the tuner off again
  #64
Old 05-27-2012, 02:35 PM
BLADE35's Avatar
BLADE35
The operating values we have are for stock programing
With a tunner things change
The other problem here is the Edge Leaves alot to be desired as far as gauges we want to look at
  #65
Old 05-27-2012, 02:44 PM
Regulator1988
I was told its bad ***
  #66
Old 05-27-2012, 02:50 PM
Regulator1988
So you know it doesn't black smoke when it's on stock tune
  #67
Old 05-27-2012, 02:52 PM
Regulator1988
  #68
Old 05-27-2012, 02:54 PM
BLADE35's Avatar
BLADE35
Well there are Bad *** as long as the truck dont break down LOL
  #69
Old 05-27-2012, 03:26 PM
BLADE35's Avatar
BLADE35
well Id say stop driving it lets take all numbers in Park leave the Tunner Off while you take Numbers
Just make shure the numbers are taken exactly like this
Truck in PARK OR NEUTRAL all times during test
ECT at 190* or close to And EOT at 185* or higher
KOEO=Key On Engine Off =record value
Low Idel (truck idel on its own)=record value
High Idel (2500RPM)=record value
And the last set of numbers are sensor operating range. If it falls out of this range I beleive a DTC/CEL will be set.
Values below are given in this order^^^Left to right
Post them Values for each on I highlighted earlier I can give you the Ford Recomended spec for each
And pray to God something will come up
  #70
Old 05-27-2012, 04:08 PM
BLADE35's Avatar
BLADE35
Looks like Edge gets a Little Bit of everything but leaves alot out
Like VGT% alot goes into figuring VGT% to get the Whole storey behind VGT% you need Baro MAP EBP MAF Boost to see if one of those is messing with it and still VGT could be bad and not moving the turbo veins to the right spots
But we check all sensors first that PCM will figure into VGT Position
I guess just a process of elimination
  #71
Old 05-27-2012, 04:23 PM
Regulator1988
How do I know my eot?
  #72
Old 05-27-2012, 04:51 PM
BLADE35's Avatar
BLADE35
Engine Oil Temp
Its best to be upto Operating temp when sensor values are taken but not a Deal Breaker espeialy the sensors we want to see
Also Mike is mentioning Trying a VGT from a another known truck cause that best way to rule that out at home
At the Dealer leval they have a special Deal they install to check the VGT operation and make shure the VGT is Moving the Veins per spec as they command with IDS
We can kinda see it work comparing VGT numbers to Boost numbers but this no where neer the Best way and Really just a Half *** Guess as there is NO Position sensor in the VGT Valve
  #73
Old 05-27-2012, 05:15 PM
Regulator1988
If I bought another valve what would be the worst that would happen
  #74
Old 05-27-2012, 05:16 PM
Regulator1988
When I first start it it white smokes... And kinda chugs then I can hear the turbo kick in and it doesn't white smoke anymore
  #75
Old 05-27-2012, 06:07 PM
bismic's Avatar
bismic
bismic is offline
Received 2,478 Likes on 1,718 Posts
The VGT valve is just plain expensive, but sometimes it might just come down to parts replacement (or take it in).
Quick Reply: HELP AGAIN
