HELP AGAIN
Old 05-25-2012, 06:22 PM
Regulator1988's Avatar
Regulator1988
Regulator1988 is offline
I don't have a scan gauge
  #32
Old 05-25-2012, 06:25 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Originally Posted by BLADE35
Have you checked any of these^^^^^^^^^^^^????????????????
And in addition VGT% at KOEO & Low iDEL & High Idel
VGT is only an actuator. There is no sensor to indicate the actual position on the VGT itself, other than to monitor how MGP (manifold gauge pressure) with the engine running at 1200 RPMs and active command of VGT duty cycle between 0% to 85%. In a normally functioning turbo, a steady increase should be observed when VGT is increased as 85% is approached (along with the turbo spool up).
In other words, the PCM can command what duty cycle it wants the VGT to do, doesn't mean its actually doing it, nor is there a position sensor inside it (and PID to monitor), just like the IPR.
For what it's worth, I find it hard to believe the OP can't get his hands on another truck with a known good VGT to borrow. These trucks are a dime a dozen, so finding another one shouldn't be difficult. I'm just trying to help save some of his money before he goes out and either blows money on a turbo needlessly (or wastes the time in the labour needed to R & R the turbo for cleaning needlessly), or blows money on the pricey VGT solenoid without first pinpointing his issue.
Monitoring MAP and BARO (no EBP on 2003s) at key-on/engine-off will only tell him if he has any biased sensors, which I'm sure he's likely already done by now. Now he needs to find out WHY he's not boosting. I'll assume he has no exhaust or intake leaks or restrictions, now it's time to pinpoint the faulty turbo component(s).
  #33
Old 05-25-2012, 07:22 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
In other words, the PCM can command what duty cycle it wants the VGT to do, doesn't mean its actually doing it, nor is there a position sensor inside it (and PID to monitor), just like the IPR.).
Mike Im right with you on the Actuator/s in the 6.0L Just Cuz it says VGT% is in one position Dont Mean its in that position Gotcha
Im Aware of the Special Diagnostic tool you guys use to Measure the actual turbo Piston Movement as you command with IDS
Mike can you tell me about the CAM Follower at the end the VGT Valve what does it do Exactly??????????
Does it just hold the piston in the Parked position or ???? Iv read and reread the turbo charger guide on this and just cant get it in my head exactly what this CAM FOLLOWER at the end of the VGTCV purpous is
School me/us on this Thanks
Now the Other Day Another guy had come here and his VGT% was stuck at 85% at all times and wouldnt Boost Well everything else checked out ok so replaced VGT and problem solved IDK maybe got Lucky
I dont think he has checked any of these yet
He said he has a CTS programmer IDK if its got gauges to or not I dont follow that stuff so I really dont know what a CTS even is Im assuming an EDGE Product but IDK for shure
  #34
Old 05-25-2012, 07:47 PM
Regulator1988
School me on this Thanks
It is a edge product. It has some gauges but not those
It is an edge product. It has some gauges but I don't think it has those
  #35
Old 05-25-2012, 10:18 PM
Regulator1988
Turned the tuner all the way up and no problems and it moves!
  #36
Old 05-26-2012, 01:06 AM
Snuggyworm's Avatar
Snuggyworm
Snuggyworm is offline
Possible tuner. It is possible tat the tuner is so integrated into the truck tat it's practically telling the truck how to run.
I'm glad Ur truck works now.
  #37
Old 05-26-2012, 11:01 AM
Regulator1988
So I need what
  #38
Old 05-26-2012, 11:05 AM
Regulator1988
A new tuner or a different one or not that tune
  #39
Old 05-26-2012, 09:35 PM
Snuggyworm's Avatar
Snuggyworm
Definitely different tune. I've heard tat the edge cts will work on some trucks n it might not work on some. Weird. I know.
Sorry if I seem distracted. I'm taking a crap at a chevron station in Houston.
  #40
Old 05-26-2012, 09:38 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Gee, thanks for sharing.
  #41
Old 05-26-2012, 09:50 PM
Regulator1988
I feel the same way lol
It still lags a lot on take off is that normal?
  #42
Old 05-26-2012, 11:08 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
LMFAO
Way more Info than we needed to know
Hope everything worked out OK Dom Best of Luck Pal
  #43
Old 05-26-2012, 11:10 PM
Regulator1988
LMFAO
Blade where r u located
  #44
Old 05-26-2012, 11:15 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Utah
about 30 minutes from Salt Lake City
  #45
Old 05-26-2012, 11:17 PM
Regulator1988
Damn, well what about my turbo question
Quick Reply: HELP AGAIN
