HELP AGAIN
05-24-2012, 11:12 PM
Quote:
Originally Posted by
Regulator1988
I'll put it on level 3 and see what's going on
DOM means return the truck to Stock programming and compleatly remove the Tuner from the Equasion
05-25-2012, 09:40 AM
on
BLADE35
Oh.... Lol don't I feel like a dumb ***
05-25-2012, 10:00 AM
Regulator1988
No Biggie Bro
Im shure you have Lots of stuff in your mind trying to figure this issue out
05-25-2012, 10:49 AM
on
BLADE35
No Biggie Bro
New turbo? Or no? Clean it?
05-25-2012, 12:56 PM
on
Ok guys took tuner completely off and it did the exact thing. Need some help. Don't know what to do. Maybe craigslist
05-25-2012, 01:14 PM
on
05-25-2012, 02:02 PM
I would start w/ the turbo cleaning
05-25-2012, 02:03 PM
on
bismic
How much of a PIA is it
05-25-2012, 02:41 PM
on
While I'm there I would just do the egr delete and either oil cooler from ford or bpd one
05-25-2012, 03:38 PM
on
If Ur gonna go with a new oil cooler, get the bpd one. It's supposed to last longer than the OEM one.
05-25-2012, 03:39 PM
on
If after cleaning Turbo, no improvement, then I'd replace it.
05-25-2012, 04:00 PM
on
Snuggyworm
I only have the money for one or the other
05-25-2012, 04:11 PM
Regulator1988
How about diagnosing your problem first, BEFORE you spend money? THAT would be a smarter move. I fail to understand why you refuse to take five minutes, as well as a ratchet and 12-point 8mm socket (which is all it takes) to remove your VGT and borrow one from another fellow member's truck to try. It appears that you are now able to duplicate the symptom more readily than you were in the previous thread you started. BTW, if it does turn out to be a bad VGT, the part number from Ford is 5C3Z-6F089-BA.
Once you fix your issue, THEN start deciding on the money you want to spend on the goodies.
05-25-2012, 04:36 PM
on
I have no one to borrow from
05-25-2012, 05:22 PM
BLADE35
Post MAP psi & EBP psi & BARO psi & MAF Volts at KOEO
Have you checked any of these^^^^^^^^^^^^????????????????
And in addition VGT% at KOEO & Low iDEL & High Idel
