Portable diesel filtration/water separator
Have you tried one of these, or another/better product.
My concerns are:
* Poorly stored cans/barrels of fuel.
* Bad/contaminated pump diesel five times in three years..
I am considering installing an in-line water separator on all of my vehicles.
It would be nice to assemble a small Portable diesel filtration/water separator that would fit in a car trunk for emergency's.
diesel water filter funnel - Google Search
diesel water separator filter - Google Search
My concerns are:
I'm not really sure what kind of truck your driving. I know the 6.0L (and up) have a water separator at the fuel "lift" pump (HFCM). Those funnels look like they'd make a mess, and I'm not convinced they'd keep the water from getting through. A good Racor water separator will do the job...again, not knowing what your driving I'm not sure how I'd recommend it's placement on your rig.
Sounds like you'd need a second fuel tank/fill spout to so that the fuel can be pumped through a Racor water separator. Like I said above, the I know the 6.0L up have the aquabloc filter membrane at the HFCM that does an excellent job of keeping water from getting to the injectors. Not sure if the 7.3L powered SuperDuties have that or not.
Example
These are generally what I would like to find or build on a smaller scale.
SSE D-Pure 600 - Separator Spares and Equipment, LLC - New and Refurbished Centrifuges - Decanter Centrifuges - WSK - GEA Westfalia - Alfa Laval - Mitsubishi - After Market and Genuine Centrifuge and Separator Spare Parts
Fuel oil filter, fuel oil filtration, gasoline oil purifier, diesel oil purifier - LD-F - SMC OIL RECYCLE (China Manufacturer) - Other
Sounds like you would need a secondary filling location to achieve what your asking as zhilton mentioned. I know there's been talk on the various boards about DIY versions that would install before or after the factory filter to help. There's even been talk about putting a drain in the tank at the lowest level to remove water at the tank rather then after.
My point in this line of thinking...volume vs time to settle. Maybe I'm not looking all sides of this...but I'm thinking you need somewhere in the fuel system for the water to settle out of the fuel then a method to block it from going any further. I don't think those funnels will do it, but I'm more than willing to learn more about what your thinking.
Hmm
AirDogII - Google Search
Here is what most McParts stores have shown me.
I have been considering one of these
diesel water separator - Google Search
with a 12 Volt Diesel Transfer Pump
Diesel Transfer Pump - 12 Volt
12 Volt Diesel Transfer Pump - Google Search
as a portable diesel filtration/water separator.
That is interesting, I will start watching auctions for a better price.
AirDoggII - Google Search
The second link doesn't look much different then the factory water separator in functionality. Wonder if they are any better.
For on truck filtering/water separation of the fuel, pre-pump but after the tank, Driven Diesel 7.3L Fuel Tank / Pre-Pump Kit is what I have on mine.
65f100_352
Alternative Fuels, Hybrids & Mileage
07-18-2007 07:07 AM
