Which truck to buy?
Which truck to buy?
Maybe this has been asked but I wish to replace my 02 V10 truck with a newer lower mileaged truck. I want a diesel. I need a 4x4 and I would like a crew cab. I can spend around 27k but less would be better. I tow a horse trailer and would like to be able to tow around 11k lbs.
I can't find a nice 7.3 and I am afraid of the 6.0 and 6.4. I drove a 6.4 and loved it but...I am afraid of it.
What is recommended?
6.0L = EGR and oil cooler failures, headgaskets, and FICM. 6.4L = HPFP, radiator. Don't be afraid of known issues, just build the likelihood of a failure happening into the purchase price based on maintenance records and bad luck. If it happens, fix it and move on, repeat failure rates are getting a lot better because both the engines have been wrung out pretty completely.
Find a 6.0L for 20k and put 5k into the engine, problems solved. Do all the maintenance and it'll last til 300k easily.
I agree with texastech about the 6.0L, the issues are well known and not impossible to preempt without spending a fortune. The 6.4L seems to have a better track record but repairs can be much more expensive when they come up. I would not suggest owning a 6.4L out of warranty unless you can afford a $10K repair bill should the high pressure fuel pump grenade.
Are you saying you want more info on the 6.4L because that's what you're interested in? I'm a little dense and hints don't work too well with me.
Looks like you're on the right track then. Towing heavy loads up hills requires a diesel IMO. It's a shame you have to do so much to make the Ford diesels reliable. $5 k to make it "bulletproof"? I dont know how Ford can be even remotely happy with that track record. It's one of the reasons I got a gasser. I always say to get the newest truck you can afford, even if it has more miles than an older truck. Just one opinion. Good luck on your search.
I found these close to you [LINK]
Lawdog734
6.4L Power Stroke Diesel
04-17-2018 04:13 PM
