Digital Documentation
#32
Howdy Rich, if your not completely fead up with sending out the links, I'am sure I could use this info as well. Thanks
Tom
2003 F350 4x4 Lariat CCSB SRW, Autometer Z Series Gauges, 4"Diamond EyeTB,
JWVB, 6.0Trans cooler, 6637, F5 DP Tuner, HPX, IH Bellowed Up-Pipes, Foil Delete, WW, Airlift Rear Bags, Zoodad, Recon LED Cab Lights, GPR-LED, 05 Mirrors, Upper Rad Hose
Tom
#33
Tom
Tom
#35
#38
#39
I could use the link also. I realized the other day when my truck broke down I have very little Powerstroke documents but tons of Ranger documents and diagrams.
I would not be too worried about the copyright issue, you are not passing the information off as your own and you are not selling the information, and it is being used for education so it should fall under the fair use case. I am not a lawyer but that is my understanding of it.
#44
In the upper left-hand corner, you will see "User CP". This is the link to the User Control Panel, where you can fine-tune your information and experience on the forum. Once you are in the control panel, you will see the area that I posted a picture of.
