Engine misses under hard acceleration - Ford Truck Enthusiasts Forums
Old 05-24-2012, 05:31 AM
07F150Lariat5.4's Avatar
07F150Lariat5.4 07F150Lariat5.4 is offline
07F150Lariat5.4 is gaining momentum as a positive member of FTE.
I've recently had a small issue with my truck missing under hard load. If you're going around 40 MPH and push it down like merging it will kick back and forth and sputter and then start hitting fine again after a few seconds and move on. Possibly bad sparkplugs and/or wires? Thanks.
Old 05-24-2012, 08:44 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Time for some spark plugs bud. SP515 is the number.
Old 05-24-2012, 10:28 AM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
X2 If you haven't tuned it you must. Also look to fuel filter and cleaning your MAF. Check for clean tight connections in the air induction system. If you have a good code reader graph your pids and document your freeze frames.
Old 05-24-2012, 09:41 PM
Thanks. That's what I'll do. Appreciate it a bunch!
Bad miss under lite accel reddogracing Modular V10 (6.8l) 1 01-10-2017 08:47 AM
2005 f150 5.4 problem roboa89 2004 - 2008 F150 19 04-06-2016 07:20 PM
98 E350 Missing After Warmed Up dubyaohohdee 1968-2013 Full Size Vans 2 10-05-2015 07:01 AM
Engine bucking and missing over 35 mph pnp522 1987 - 1996 F150 & Larger F-Series Trucks 0 08-10-2015 01:28 PM
engine missing under acceleration tored1971 2004 - 2008 F150 10 02-27-2011 06:40 PM
Tags
03, 2006, 46, 94, acceleration, engine, explorer, ford, hard, heavy, miss, misses, missing, pickup, ranger, roush
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
