Just bought a 1954 F100, Want to 302 & AOD What do I need? - Page 2 - Ford Truck Enthusiasts Forums
Old 04-03-2014, 08:57 AM
70BumpClubCab's Avatar
70BumpClubCab 70BumpClubCab is offline
70BumpClubCab is starting off with a positive reputation.
One option to ponder
I scored a complete running driving 85 crown Vic and decided to use it for all mechanicals and electrical and just subframe the truck. Your truck should have the same wheelbase where mine had to be extended 8" from the original car chassis. I have a build thread out there somewhere. Just think of it as using the stock chassis from cab mount to running board mount as a sling, inside the stock car chassis dimensions . My parts are mostly stocked on the shelf locally with some options to upgrade, and carb converting the 302 from cfi was easy to do. No ecu to wire or keep smog system active.
Old 04-03-2014, 09:02 AM
Branded Branded is offline
Branded is gaining momentum as a positive member of FTE.Branded is gaining momentum as a positive member of FTE.
Clayton Bennett had a total of 3 post, he has vanished. and hasnt post since 2012.
<TABLE border=0 cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD id=username_box vAlign=top width="100%">
Clayton Bennett
</TD></TR></TBODY></TABLE>Last Activity: 05-27-2012 03:13 PM
Old 04-03-2014, 03:23 PM
das54's Avatar
das54 das54 is online now
das54 has a good reputation on FTE.das54 has a good reputation on FTE.
Way to go Ax! just kidding. Who knows, you might have saved the guy his marriage or at least a huge disappointment. The stark truth is good. There is a reason High Schools often have a rally where they display a mangled wreck with a cheerleader covered in fake blood hanging halfway out the busted windshield.
Old 04-08-2014, 02:02 PM
Speedcanuck's Avatar
Speedcanuck Speedcanuck is offline
Speedcanuck is starting off with a positive reputation.
MO? not sure where ya got that, but the Truck originated in Manitoba, Canada. I'm rebuilding her in Alberta. If ya got pics of your truck, post a link and I'll check it out.
Old 04-08-2014, 03:13 PM
das54's Avatar
Quote:
sometimes these threads get a bit tricky. Back on post #8 the original poster said he was from MO. This is one reason it's nice if everyone added there location to their profile - just say'n - hint hint nudge nudge.
Baddog's '67 Build Baddog671 1967 - 1972 F-100 & Larger F-Series Trucks 26 05-26-2016 03:17 AM
Chassis swap our1954 1948 - 1956 F1, F100 & Larger F-Series Trucks 43 07-26-2014 07:38 PM
78 F250 Ranger Lariat "Big Green" Buyerz Projects 3 07-06-2014 11:15 AM
*PICS* New '12 FX4, 26s with 40 series tire 35 series? possible? ChargerOnDavins 2009 - 2014 F150 16 03-10-2014 03:47 PM
my first restoration 1954 Ford f 100 RichardBousack 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 01-15-2012 07:13 PM
Tags
1954, 302, 55, aod, canada, custom, ford, made, mount, powered, radio, trans, truck, vbulletin, xm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
