Muffler sounds like it has golf ball inside. - Ford Truck Enthusiasts Forums
Old 05-24-2012, 01:26 AM
DieselBeast01's Avatar
DieselBeast01 DieselBeast01 is offline
DieselBeast01 is gaining momentum as a positive member of FTE.
So my exhaust started to make a rattling sound about a week ago. I had it changed from rear duals out the rear to dual pipes out the passenger side in front of the tire right after I bought the truck 6 months ago. The muffler shop simply moved the exsisting flowmaster closer to the fornt of the truck and rerouted the exit pipes. When I first heard this rattle, I assumed that it was a loose hanger. I called my muffler shop, and they said bring it in and they would weld it back for free since it has only been five months since they rerouted it for me.
This morning I got under the truck with it running to try and figure out which hanger it was before I took it to the shop. All the hangers were tight and there were no broken welds at all. I have a flowmaster muffler on the truck. While the truck is idling, it sounds as if there is a golf ball or something rattling around inside it.
I know that there are chambers and fiberglass and what not inside the flowmaster mufflers that give it the aggressive tone and that they can go bad just like any other muffler. I am not sure when the flowmaster was installed, but I imagine the previous owner had it put on when the truck was new. My truck is an 05 but only has 45k on it so the muffler can't have any more miles than that.
Has anyone ever experienced this with a flowmaster muffler? My exit pipes are pretty short (about a foot and half from muffler exit to end of tip) and possibly someone could have put something in one and it made it to the muffler but I would hope that is not the case. Has anyone else had a flowmaster muffler go bad in 50k or less?
Old 05-24-2012, 04:25 PM
paxmann paxmann is offline
paxmann is starting off with a positive reputation.
Flowmaster
I had a similar situation with a flowmaster years ago.. it was at around 30,000 km's.. one of the chambers broke loose and was rattling up a storm.. once replaced I never had another issue with it and the replacement had about 100,000 km's on it when I sold the vehicle...
Old 05-24-2012, 07:00 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
Flow****ter's are notorious for their welds breaking loose inside the muffler and doing exactly what you are describing. Id weld up a better muffler if i wereyou, eith Cheery Bomb, Borla, or Magnaflow
Old 05-25-2012, 01:38 AM
I've had several trucks with flowmasters on them and none have had this problem. I heard an f150 with a magnaflow the other day, and I think I may try them out this time around.
Old 05-25-2012, 09:23 AM
FX4 SilverScrew FX4 SilverScrew is offline
FX4 SilverScrew is starting off with a positive reputation.
You will be better off trashing that crap muffler for a Magnaflow.
Flowmaster Series 70 muffler and DRONE!!! HELP!! Lizard 1 Modular V10 (6.8l) 23 04-08-2014 12:55 PM
Magnaflow muffler installed today. DieselBeast01 2004 - 2008 F150 11 08-07-2012 02:15 AM
Single pipe exhaust configuration IcutMetl Exhaust Systems 1 06-05-2010 09:35 PM
V-Force Mufflers mwc4275 Exhaust Systems 1 08-26-2002 11:10 AM
460 dual exhaust fordpower460 Exhaust Systems 3 11-27-2001 04:27 PM
Tags
bad, ball, coming, flowmaster, gear, golf, muffler, rattling, sounds
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
