Viair system installed. Love it! - Page 3 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
  #31
Old 07-15-2014, 04:16 PM
golfmedik's Avatar
golfmedik golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
Quote:
Originally Posted by BulletsForFingers View Post
Got any pics of that? I get the brackets for the tank, but he's mounted that compressor right on the side of the frame.
Will try to get you a pic of the compressor I did later tonight. All I did was sandwich the frame with two pieces of steel and two bolts and nuts. No problems since.
  #32
Old 07-15-2014, 05:48 PM
golfmedik's Avatar
Quote:
Originally Posted by GHeTTo JOe View Post
the kits i have seen have two brackets that are on either side of the frame and have bolts holding them together on the top and bottom of the frame.
Here is how I did it on my '13 with the same Viair kit as on my 6.4L.
Hope this helps as another way of doing it.
  #33
Old 07-20-2014, 11:09 PM
BulletsForFingers BulletsForFingers is offline
BulletsForFingers is starting off with a positive reputation.
Just a follow up, I finished my install over the weekend. I forgot to snap a pic of the compressor, but I used the same hanger concept. I just mounted it on the bottom rail so it sits right side up.
(don't worry, I swapped that safety release for the draincock on top that you can't see :P. This was a mid-install pic)
  #34
Old 03-25-2015, 09:35 AM
93-331-29PSI 93-331-29PSI is offline
93-331-29PSI has a good reputation on FTE.93-331-29PSI has a good reputation on FTE.
I'm getting ready to install my onboard air and want to thank everyone for some great ideas, think I'll be using a little from each to get mine done.
Where did you get this switch panel?
Finally! New X/C code springs in! golfmedik Excursion - King of SUVs 88 06-03-2016 08:02 PM
Hard time installing Viair on '13 6.7 golfmedik 6.7L Power Stroke Diesel 16 11-25-2013 11:58 AM
Viair Install Complete with Pics... golfmedik 6.7L Power Stroke Diesel 10 11-24-2013 12:00 PM
Walked away from my 6.4 today.. golfmedik 6.4L Power Stroke Diesel 16 10-25-2013 11:20 PM
Re-ringed Injectors = Fuel Mileage Increase golfmedik Excursion - King of SUVs 0 11-14-2012 10:29 AM
Tags
10007, 2008, compressor, f250, install, installation, installing, painting, powered, stroke, superduty, toolbox, vbulletin, viair, walls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
