Help with sensors... 7.3L
Can't seem to find a part number listing for the "Engine Temperature Warning Lamp Sensor" located in the driver side head (image 1), and I was wondering if you guys might have a Ford or International part number for it...
The other sensor (image 2), the exposed two-prong sensor on the passenger side head just underneath the water neck... What is it, and any idea what that part number could be?
The coolant sensor in the block is a single post top (# TS6628), the one in the head is a single post as well, not the # TS4060 (that's a two-prong enclosed). Looks more like a NAPA/Echlin # TS6715. NAPA has no listing for the Cold Idle sensor. Is my best bet to call International?
Temperature Switch | 1992 Ford F250 3/4 ton P/U 4WD 8 Cylinders M 7.3L Diesel | AutoZone.com This is probably what you are looking for, I would think.
golfmedik
6.7L Power Stroke Diesel
15
12-31-2023 05:47 AM
jayro88
12-26-2013 03:32 PM
