Turn Signal - Ford Truck Enthusiasts Forums
Turn Signal
Old 05-23-2012, 10:17 PM
sranderle sranderle is offline
sranderle is starting off with a positive reputation.
Turn Signal
Can the quick turn signal be reprogrammed from 3 to 5 or some other number of flashed? I could make this change on a previous VW Touareg.
Old 05-24-2012, 12:12 PM
04XLTRUNNER's Avatar
04XLTRUNNER 04XLTRUNNER is offline
04XLTRUNNER is gaining momentum as a positive member of FTE.04XLTRUNNER is gaining momentum as a positive member of FTE.
i have been wondering the same thing. seems like 5 flashes would be a better time than just 3. Might want to check in the manual but i dont think it could be changed
Old 05-24-2012, 12:33 PM
kmonty2's Avatar
kmonty2 kmonty2 is offline
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
It does flash longer when you have a trailer connected. But I don't think it can be changed.
Old 05-24-2012, 08:04 PM
Going_Going_Gone Going_Going_Gone is offline
Going_Going_Gone is gaining momentum as a positive member of FTE.
The three-flash feature (we have it on our car) takes a while to adapt to, but is a nice feature. What I can't figure out is why they changed the lever to activate the bright lights by pulling all the way back instead of pushing forewords like it's been forever...I consider that a step backwards. A couple of times I've flashed the brights to alert someone cutting me off and turned them on inadvertently.
Old 05-24-2012, 10:33 PM
PrinceValium's Avatar
PrinceValium PrinceValium is offline
PrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to all
I wonder if you can just plug in a wire connector from a trailer and it will think it is towing something and then give you the 5 flash signal all the time?
Old 05-25-2012, 07:53 AM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
when did they add this feature?
my 2010 XL does not have it.
maybe it's an XLT & up thing?
Personally, i think it's just another gimic ... but then again, i'm glad that other's have it. keeps those "one flasher's" a little more honest
Old 05-25-2012, 08:00 AM
BigDfromTN's Avatar
BigDfromTN BigDfromTN is offline
BigDfromTN is gaining momentum as a positive member of FTE.BigDfromTN is gaining momentum as a positive member of FTE.
Quote:
Thats what I was wondering...
My 2011 has it in Lariat trim.
Old 05-30-2012, 04:06 AM
I believe it was a feature added to the 2011's if I am not mistaken. Personally I wish it was 5 for normal turning and 7 for when towing. It would be nice to be able to set the number of turns from the nav screen!
Old 05-30-2012, 11:01 AM
The79Beast's Avatar
The79Beast The79Beast is offline
The79Beast is starting off with a positive reputation.
My XLT has it
Old 05-31-2012, 01:12 PM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
Quote:
Originally Posted by The79Beast View Post
My XLT has it
It was an across the board change in 2011 regardless of trim level.
2005 Turn signal switch Larry Grimes Excursion - King of SUVs 3 11-24-2014 05:39 PM
95 front turn signal issue Freightrain 1987 - 1996 F150 & Larger F-Series Trucks 4 03-06-2014 10:29 AM
Turn signal problems Duke78 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-17-2010 05:58 AM
Turn Signals Yeti 1999 to 2016 Super Duty 5 09-19-2002 05:08 AM
Turn signals rwjr 1973 - 1979 F-100 & Larger F-Series Trucks 8 10-12-2001 01:35 AM
Tags
1977, cuts, engine, ford, signals, truck, turn, turned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
