Replace crank cap bolts? - Ford Truck Enthusiasts Forums
Old 05-23-2012, 07:24 PM
rayinsd's Avatar
rayinsd rayinsd is offline
rayinsd is starting off with a positive reputation.
Question Replace crank cap bolts?
I'm going through my 1998 4.6 triton @193K mi and have a question. I have new stretch bolts for my freshly done heads but the nbook calls for new hardware at the main caps as well. First of all, I can't find a good local source here in San Diego and an engine builder here says he never replaces the main or con rod hardware and has never had an issue. Don't expect to get much support for this plan but, really, how risky is this?
Old 05-23-2012, 08:32 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Well considering the main and rod bolts are torque to yield and the factory stretches them during assembly why would you not replace them? It would be a shame to trash a freshly rebuilt motor over a $10 bolt. I would at least replace the rod bolts.
Old 05-24-2012, 12:49 PM
rayinsd's Avatar
Thanks longbed. I'll getthe con-rod hardware coming. Cap bolts too if I can find them.
Rebuilder Question puffen:D 1999 - 2003 7.3L Power Stroke Diesel 6 10-23-2014 02:57 PM
4.9 300 main cap bolt Fastolds WTB - Parts & other 1 12-18-2012 09:14 AM
HELP! Main cap bolts---Need to buy new the_goon 3.8 & 4.2L V6 1 08-16-2010 05:45 PM
Solution to ARP rear main cap clearance. maxtor FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 04-16-2009 02:33 PM
Milodon 4 Bolt Main Caps ... jamies460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 07-28-2007 07:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
