First post. Little help please - Page 2 - Ford Truck Enthusiasts Forums
Old 05-26-2012, 10:15 PM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
Originally Posted by JayzDaddy View Post
Any info from the sticker as to what i have
1FTEF14Y6GKB45018 (I think that's what it is, it's hard to tell for sure in that photograph)
1FT = World Mfr. Identifier = Ford Motor Company USA Truck (Complete Vehicle)
E = Brakes/GVWR = standard brakes, 6,001 - 7,000 lbs.
F14 = Series Code = F150 Truck -- 4WD
Y =Engine Code = 4.9L / 300 cid gasoline-powered 6-banger
6 = Check Digit (ignore)
G = Model year = 1986
K = Assembly Plant Code = Kansas City
B45018 = Production Sequence Number
WB = 117" Wheelbase
TYPE-GVW = F141 = 117" WB Pickup 6,100 lbs. GVWR F150 4WD
BODY L84 =
................L8 = F150/350 Blue cloth & vinyl, bench seat
.................4 = Regular cab w/styleside pickup box
TRANS = A = New Process 435 4-speed manual
AXLE = 18 = 3.00:1, 3,800 lb. capacity Ford non-locking (Axle Code 18 is 3.08:1 beginning in 1987)
EXTERIOR COLOR = 7B = Shadow Blue Metallic acrylic enamel
DSO = 17 = Washington (Original-purchasing dealer location)
I don't bother anymore trying to look up Spring Codes (for you, Front = C, Rear = L) as there isn't any useful information to be gotten from them, at least not from the parts book.
Source: FoMoCo 1980/89 Light Truck Master Parts Catalog
Old 05-26-2012, 11:05 PM
JayzDaddy's Avatar
JayzDaddy JayzDaddy is offline
JayzDaddy is gaining momentum as a positive member of FTE.JayzDaddy is gaining momentum as a positive member of FTE.
Holy crap. Ctu i appreciate it but you didnt have to type all of that. Must have been like work.
Can anyone tell me about the axle..... Like in 4x4 is this like my explorer and open diff or limited slip
Old 05-26-2012, 11:26 PM
ctubutis's Avatar
Yeah, it takes a fair while to look up all that stuff but ya get used to it, I guess.
It's an open (non-locking) axle.
V/Modified B codes, step-by-step robert_l_ross Excursion - King of SUVs 233 04-21-2016 09:16 AM
Rust repair and patch panel forming AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-02-2014 12:43 PM
Door to front cowl/fender seam adjust? hardknox00001 Paint & Bodywork 2 03-30-2014 08:32 AM
53-56 Front sheet metal alignment procedure AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 02-12-2011 09:38 AM
Fender Cowl/Hood Gap - Was fender part # revised? 73FOMO 1973 - 1979 F-100 & Larger F-Series Trucks 12 04-28-2009 03:39 PM
Tags
adjust, borg, clutch, f150, rod, t18, warner, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
