Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Nebraska Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Nebraska Chapter Join Chapter, Leader: 97nukeford
  #1 (permalink)
Old 05-23-2012, 10:53 AM
1978Quinn 1978Quinn is offline
Garage is empty, add now
1978Quinn is starting off with a positive reputation.
1978 Brocno EFI Conversion
I was tired of a carb and wanted to do something to my old bronco that, from my searching had not been done that many times, install fuel injection. I did a little checking into all of the "kits"-Holley, Fast EFI ect., they all seemed to have one thing in common, they were expensive. I decided to go the Megasquirt route due to the cost and being able to use parts from the junkyard to make it work. My fist stab at doing this was buying a complete engine out of an 1989 F250, I was going to switch the heads, the heads on efi 460s and carb'd 460s are different, my plan was to switch the heads and use the efi intake manifold, dist., and wire up the ecm. Turned out the efi heads were cracked, so went to plan "b". I sent my carb'd intake manifold out and had injector bungs and fuel rails made. Then I adapted the upper intake plenum to the carb manifold. The fuel system was pretty straight forward installed an electric fuel pump, supply line, return line, and pressure regulator. The rest of the wiring was also straight forward, coolant temp, air intake temp, dist. ground and signal, o2 sensor-used a wide band kit from Innovative Motorsports- coil ground, TPS. I also added a two speed electric fan so a couple of relays for that as well. I used the serpentine belt brackets, pulleys, but pulled half off a van so I could get the Saginaw p/s pump. This is pretty much where I am at now, as with most projects there are two parts that are always hard to find, time and money.
Thanks
Quinn
Click the image to open in full size.
  #2 (permalink)
Old 06-07-2012, 09:44 AM
67nukeford's Avatar
67nukeford 67nukeford is online now
Nebraska Chapter LDR
1997 Ford F-150
My Garage
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
Quinn, great info! I'm trying to decide if I'm going to do EFI on my 67, with the 351 I robbed out of an 89 F-250. Didn't want to use the factory one, too much of a mess with the factory wiring.
__________________
Pat W. Nebraska Chapter Leader and Official #1 Slackmaster/ Avid Winter Hater
2006 F-250 "Black" ARP studs, EGR delete, SCT tuner REBUILD THREAD
1967 F-100 4X4
1967 F-100 Project thread
2013 Explorer XLT (wifeys)
CLICK HERE TO JOIN THE NEBRASKA CHAPTER!
  #3 (permalink)
Old 06-07-2012, 10:21 AM
Pat, that small block would be easier to get working that what I had to do with my 460. The wiring is not that difficult if you take it one circuit at a time, I disected the factory efi harness off the doner motor I bought and you end up only using about 1/2 the wires in the factory harness since you are getting rid of all the emissions controls. There is also a ton of performace parts available for small efi fords, and you can get it pretty cheap used. Check out MegaSquirt Engine Management Systems this is what got me thinking that I could add efi to my Bronco. If you decide to go this route and need a hand let me know I may be able to assist.
Thanks
Quinn
  #4 (permalink)
Old 06-07-2012, 10:42 AM
67nukeford's Avatar
1997 Ford F-150
My Garage
Thanks, I'll check that out! I'd rather have this decided before I get the engine done, since it will effect what cam I get.
__________________
1967 F-100 4X4
Tags
1978, conversion, efi, f150
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
