Where is my 302 casting numbers
Old 05-23-2012, 09:59 AM
Daltonsheets1995's Avatar
Daltonsheets1995
Daltonsheets1995 is offline
Where can I find the casting number on my engine? It's a 1982 f100 with a 302.
Old 05-23-2012, 11:47 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,661 Likes on 1,343 Posts
I have heard there are numbers on the side of the block above the starter area.
Old 05-23-2012, 11:55 AM
Daltonsheets1995
Ok thank you. I'm jus trying to see If this engine is the original
Old 05-23-2012, 01:13 PM
83capril's Avatar
83capril
83capril is offline
If you want to know if it's original to the truck then you need to look on top behind the intake manifold. There should be a flat spot right where the Trans bolts to the engine with a partial vin on it that will match your trucks.
Old 05-23-2012, 09:53 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
I have never ever seen a Ford engine with a partial vin. The engineering number above the starter as well as the date stamp in the lifter valley are all that I have seen. As far as I know there is no narrowing it down to the exact engine that the truck came with, only that it was built around the right time to have been put in from the factory.
Old 05-23-2012, 10:27 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
This is my understanding also, there is no way to match up any specific engine to any particular vehicle via any sort of "matching numbers" on a Ford.
My M-block has the standard Casting ID down by the starter motor and a casting date on the back by the oil pressure sender, I understand there's an Engine Assembly date stamped into the front near the timing case cover but that's unsubstantiated rumor, I don't know if I ever found that on my block or not.
Old 06-01-2012, 01:17 PM
83capril's Avatar
83capril
83capril is offline
Not to argue with you guys.....
I had a 1968 Mercury Montego. With the partial vin stamped in it. If I knew where the warranty card was and could get a pick of the engine where it's stamped I'd show you. Here is some help to back up my statement...
Yet on the same hand ctubutis is correct as you can't narrow down a "numbers matching" car. It's all half a dozen to one type thing. So take it as you may.
Hey Foxchassis - Four Eyed Forums
All VIN locations? - Four Eyed Forums
Engine block ID help please - Four Eyed Forums
What year did Ford start putting Vin# on engine block? - Vintage Mustang Forums
If you need more here you go...
https://www.google.com/search?hl=en&....0.JciO2I_qR3c
fish-albuq
04-29-2012 03:26 PM
1950AK
20
12-19-2010 10:30 AM
Cheap_hotrod
04-01-2003 10:54 PM
mudslinger_82
02-16-2002 05:35 PM
Quick Reply: Where is my 302 casting numbers
