Modular V10 (6.8l)
How Much oil does the V10 hold
Old 05-05-2003, 08:55 AM
mptai's Avatar
mptai
mptai is offline
Exclamation How Much oil does the V10 hold
I was wondering if the 5.4 V8 holds around 6.5 qts, how much does the V10 hold. Is it the same of more. Just Curious.
Old 05-05-2003, 09:31 AM
MountainHound's Avatar
MountainHound
MountainHound is offline
The owner's manual for my '03 states 6 qts for the V10 and 5.4L including filter change.
Old 05-05-2003, 04:47 PM
dellbert's Avatar
dellbert
dellbert is offline
MY 2002 F350 V-10 IS 6 WITH THE FILTER
Old 05-05-2003, 05:02 PM
gkateley's Avatar
gkateley
gkateley is offline
Mine hold 6.5 with filter change. If I use 6 then run the motor for a couple mins, shut it off and let it sit for awhile it takes 1/2 qt more to bring to full.
Old 05-05-2003, 09:42 PM
HD Power's Avatar
HD Power
HD Power is offline
Mine holds 6 quarts as well...fluid and filter.
Old 05-09-2003, 11:04 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
6.2 quarts with filter change. I read it somewhere, that it's 6.2 quarts, maybe in the owner's manual. But damn sure, it takes just slightly more then 6 quarts to hit the full mark on the dipstick.
ak
Old 05-12-2003, 09:14 AM
tankhead's Avatar
tankhead
tankhead is offline
I have a magazine article saying it takes 7 quarts to fill. Mine takes about 6 1/2.
Old 05-14-2003, 10:19 PM
Btravelen's Avatar
Btravelen
Btravelen is offline
https://www.ford-trucks.com/forums/s...hreadid=114784
Check this discussion also.
Old 05-15-2003, 03:51 PM
Steelheader14's Avatar
Steelheader14
Steelheader14 is offline
Cool How Much oil does the V10 hold
Both hold (need) six quarts, not 6.2 or 6.5, according to the 'book'. BUT...you can put in another half a quart if it makes you feel better.
Old 05-16-2003, 01:37 PM
203008581's Avatar
203008581
203008581 is offline
I put 7 in mine.........didn't realize you could put in less. I don't have the owners manual.
Old 05-19-2003, 12:37 AM
lonewolf1000's Avatar
lonewolf1000
lonewolf1000 is offline
Well I must put my 2 cents in. Almost all V-10 only need 6 quarts too get within the safe mark. You do not need to fill it to the top of the safe mark. Any good mechanic will tell you not to fill to the very top except on motors with alot of miles that needs all the lube it can get.A little less than full better than over full. I only put 6 qts. with oil change in mine that way I get two changes out of one case. And that brings it within a 1/8 of a quart below the full mark which is where it was from new. Had it changed once by dealer and asked mechanic. He said he only puts 6 qts in.{ well thats my 2 cents. }
v10power
Modular V10 (6.8l)
68
11-10-2023 01:52 PM
bbf150
09-16-2012 04:21 PM
1badcj8
1999 to 2016 Super Duty
145
09-02-2012 10:50 PM
rockstarf150
1997 - 2003 F150
02-07-2012 05:37 AM
2X53
04-04-2011 09:39 AM
Quick Reply: How Much oil does the V10 hold
