How Much oil does the V10 hold - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 05-05-2003, 09:55 AM
mptai mptai is offline
mptai is starting off with a positive reputation.
Exclamation How Much oil does the V10 hold
I was wondering if the 5.4 V8 holds around 6.5 qts, how much does the V10 hold. Is it the same of more. Just Curious.
Old 05-05-2003, 10:31 AM
MountainHound's Avatar
MountainHound MountainHound is offline
MountainHound is starting off with a positive reputation.
The owner's manual for my '03 states 6 qts for the V10 and 5.4L including filter change.
Old 05-05-2003, 05:47 PM
dellbert dellbert is offline
dellbert is starting off with a positive reputation.
MY 2002 F350 V-10 IS 6 WITH THE FILTER
Old 05-05-2003, 06:02 PM
gkateley gkateley is offline
gkateley is starting off with a positive reputation.
Mine hold 6.5 with filter change. If I use 6 then run the motor for a couple mins, shut it off and let it sit for awhile it takes 1/2 qt more to bring to full.
Old 05-05-2003, 10:42 PM
HD Power's Avatar
HD Power HD Power is offline
HD Power is starting off with a positive reputation.
Mine holds 6 quarts as well...fluid and filter.
Old 05-10-2003, 12:04 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
6.2 quarts with filter change. I read it somewhere, that it's 6.2 quarts, maybe in the owner's manual. But damn sure, it takes just slightly more then 6 quarts to hit the full mark on the dipstick.
ak
Old 05-12-2003, 10:14 AM
tankhead's Avatar
tankhead tankhead is offline
tankhead is starting off with a positive reputation.
I have a magazine article saying it takes 7 quarts to fill. Mine takes about 6 1/2.
Old 05-14-2003, 11:19 PM
Btravelen's Avatar
Btravelen Btravelen is offline
Btravelen is starting off with a positive reputation.
Old 05-15-2003, 04:51 PM
Steelheader14 Steelheader14 is offline
Steelheader14 is starting off with a positive reputation.
Cool How Much oil does the V10 hold
Both hold (need) six quarts, not 6.2 or 6.5, according to the 'book'. BUT...you can put in another half a quart if it makes you feel better.
Old 05-16-2003, 02:37 PM
203008581 203008581 is offline
203008581 is starting off with a positive reputation.
I put 7 in mine.........didn't realize you could put in less. I don't have the owners manual.
Old 05-19-2003, 01:37 AM
lonewolf1000 lonewolf1000 is offline
lonewolf1000 is starting off with a positive reputation.
Well I must put my 2 cents in. Almost all V-10 only need 6 quarts too get within the safe mark. You do not need to fill it to the top of the safe mark. Any good mechanic will tell you not to fill to the very top except on motors with alot of miles that needs all the lube it can get.A little less than full better than over full. I only put 6 qts. with oil change in mine that way I get two changes out of one case. And that brings it within a 1/8 of a quart below the full mark which is where it was from new. Had it changed once by dealer and asked mechanic. He said he only puts 6 qts in.{ well thats my 2 cents. }
how much does c4 hold, dipstick length? bbf150 Clutch, Transmission, Differential, Axle & Transfer Case 2 09-16-2012 05:21 PM
V-10 VS Diesel --- And now ?? for 6.0Strokes 1badcj8 1999 to 2016 Super Duty 145 09-02-2012 11:50 PM
5.4 2 v weight rockstarf150 1997 - 2003 F150 2 02-07-2012 06:37 AM
1985 F-600 370-4V 2X53 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 04-04-2011 10:39 AM
v10 power v10power Modular V10 (6.8l) 28 03-07-2008 12:27 AM
Tags
2000, 54l, 68l, 99, engine, excursion, f250, ford, hold, motor, oil, quarts, quatrs, triton, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
