2004 F150 5.4 COP + AC Compressor Issue - Ford Truck Enthusiasts Forums
Old 05-23-2012, 07:56 AM
dbarton8541 dbarton8541 is offline
dbarton8541 is starting off with a positive reputation.
The truck stutters, rpm's drop slightly and Compressor stops blowing cold air. It did this intermittingly for a day usually around the 55 mph mark, but no always, somtimes slower sometimes faster. No engine light came on. Next day engine light comes on and gives a PO352 Code. I played w #2 COP, connected/disconnected etc, and helped the situation but didnt solve it. I'm puzzled about how the AC Compressor is related to the COP issue. Will the PCM shut off compressor when a cylinder is missing? Was hoping to get some expert opinions. Thanks in advance for any insight you can provide.
Old 05-23-2012, 10:42 AM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
I would look to the spark plugs first, and take a compression test while at it. Faulty spark plugs brings about COP failures many times. Look to temp sensor faulty if motor going into limp mode. Check your air induction to make sure it is all connected tight. The change of airconditioning may be a loss of Vacuum, with the doors turning to defrost?
2005 V10 3 valve miss fire under certain conditions FordCamping Modular V10 (6.8l) 18 01-17-2017 11:24 PM
broken AC compressor mount bpbyrne 6.0L Power Stroke Diesel 2 05-16-2016 08:00 PM
1999 7.3l AC issues cokewithvanilla 1999 to 2016 Super Duty 0 05-02-2015 09:32 PM
Overdrive OFF light code and misfiring COP s kraylake Excursion - King of SUVs 0 03-26-2015 07:19 AM
Beeping/Whistle after changing COPs magee913ford 2004 - 2008 F150 2 01-14-2015 08:03 AM
Tags
04, 150, 2004, 2005, 54, ac, activates, buy, compressor, cop, cops, f150, ford, jump, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
