2004 F150 5.4 COP + AC Compressor Issue
Old 05-23-2012, 07:56 AM
dbarton8541's Avatar
dbarton8541
dbarton8541 is offline
The truck stutters, rpm's drop slightly and Compressor stops blowing cold air. It did this intermittingly for a day usually around the 55 mph mark, but no always, somtimes slower sometimes faster. No engine light came on. Next day engine light comes on and gives a PO352 Code. I played w #2 COP, connected/disconnected etc, and helped the situation but didnt solve it. I'm puzzled about how the AC Compressor is related to the COP issue. Will the PCM shut off compressor when a cylinder is missing? Was hoping to get some expert opinions. Thanks in advance for any insight you can provide.
Old 05-23-2012, 10:42 AM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
I would look to the spark plugs first, and take a compression test while at it. Faulty spark plugs brings about COP failures many times. Look to temp sensor faulty if motor going into limp mode. Check your air induction to make sure it is all connected tight. The change of airconditioning may be a loss of Vacuum, with the doors turning to defrost?
Fiveacre
1997 - 2003 F150
07-31-2019 09:12 AM
llh
05-21-2018 08:52 AM
hardeyf150
2009 - 2014 F150
03-13-2017 06:39 PM
cue ball
1997 - 2003 F150
07-06-2007 06:39 AM
Alby
04-05-2005 09:53 PM
Quick Reply: 2004 F150 5.4 COP + AC Compressor Issue
