01 excursion V10 o2 sensors - Ford Truck Enthusiasts Forums
Old 05-22-2012, 11:36 PM
Locksmith1 Locksmith1 is offline
Locksmith1 is starting off with a positive reputation.
Hi guys, Looking for a little info if anyone has it...
01 excursion V10
My AE is showing a o2 sensor ( b1s1 or b1s2 - I forget which ) is flat at 0v and the fuel trim is 99.03. In comparison to the other o2 sensor, Im guessing it has gone bad ( No Code )
1. Am I correct to assume that there are only 2 as the AE system only show b1s1 and b1s2 ?
2. Is it worth it to replace both / all 3 / all four ?
3. Brand ?
Thanks.
Old 05-22-2012, 11:45 PM
carnutt carnutt is offline
carnutt is starting off with a positive reputation.
02 sensors
there are 4..b1s1 @b1s2 are on one side and b2s1 @b2s2 are on the other side ...sensor one before CAT sensor 2 is after CAT..hope it helps ..replace one at a time they are aprox 90 bucks each
Old 05-23-2012, 08:45 AM
My AE told me which one, but it only showed 2 b1s1 and b1s2... Thanks
Old 05-23-2012, 12:39 PM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
My 03 only has 2 - went ahead and replaced both when the heater on one of mine went out.
Old 05-23-2012, 06:33 PM
ComputerCowboy's Avatar
ComputerCowboy ComputerCowboy is offline
ComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to beholdComputerCowboy is a splendid one to behold
Wink
Quote:
There are only two sensors yes, however there is one on each manifold and NONE after the CAT.
Since the truck is over 8,500 GVWR Ford didn't have to put sensors after the CAT. The EPA regulations are more lenient for larger light trucks. This is a good thing because I means you can kill the CAT without tricking out the computer with simulators.
Old 05-23-2012, 08:11 PM
Thanks again for the info.
I went under tonight after work and looked and looked and looked. I can only see 2 as stated here. My AE Software shows only 2.
B1S1 voltage varies from .1 to .8 and the fuel trim is pretty much around 0
B1S2 voltage is reading 0.00 and fuel trim is 99.03
So, I got the tool and the sensor and changed the one that was easier to get to... The Drivers side. And B1S2 is still not functioning
What I am coming up with is :
B1S1 is Drivers side
B1S2 is Passanger Side.
Is this correct ?
Which is completely opposite to what I have read in other posts...
B1S1 Front Pass
B1S2 Rear Pass Side
B2S1 Front Driver
B2S2 Rear Driver
Old 05-23-2012, 08:13 PM
And what confused matters, The guy at the parts store asked me which one I wanted... Pre or Post Cat..
Old 05-25-2012, 07:07 PM
Now I have replaced both o2 sensors and there is still 0v out of B1s2...fuel trim is still at 99.03 ...
I dont mind doing the work unless Im wasting my time and money... Getting my arm stuck in the exaust is not fun... Being trapped under the truck with my arm stuck in the exaust is even less fun...
Any Ideas?
Old 05-25-2012, 07:45 PM
nzirbel nzirbel is offline
nzirbel has a good reputation on FTE.nzirbel has a good reputation on FTE.
Clean your MAF sensor and reset the computer. I know it sounds dumb but it might be the cure. I had a code checked and it pointed towards a bad pass o2 sensor. Had it reset and the next time it said bad drivers o2 sensor. Did some research, cleaned the maf and reset the computer and no more problems or codes!
Old 05-25-2012, 08:09 PM
I will do that... How clean ? With what ?
The o2 was not giving a code.. Just the AE showed it not having any output voltage. From Im guessing now the O2 sensors were not bad. I guess AE only supports B1S1 and B1S2 which from what I gather are both on the Pass side however, There are not any O2 sensors after the Cat. But I did notice that the overhead trip computer is More responsive, The MPH had began to change a little as I drove and after changing the other 02 sensor, it really changes with the amout of throttle I use..which before It might have changed only .1 MPG in a day.. and now it will drop to 0 MPG is sitting at idle for a few minutes, Before It would only say 8.5..
Old 05-25-2012, 08:15 PM
maybe change the o2 sensors will take care of the P1000 ( readiness not complete ) which has been showing since I got the truck ( 2 yrs )
Old 05-25-2012, 08:18 PM
Clean it with MAF sensor cleaner or quick dry electronics cleaner, there was a write up on it not too long ago.
Old 05-25-2012, 08:23 PM
I never heard of it.. But thanks
Ill let you know
Old 05-25-2012, 08:41 PM
TrdLtly's Avatar
TrdLtly TrdLtly is offline
TrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputation
wpnaes's Avatar
wpnaes wpnaes is online now
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Quote:
http://www.ford-trucks.com/forums/10...eanup-day.html
Article: How To Remove Your EGR Valve DasCheckers 1987 - 1996 F150 & Larger F-Series Trucks 23 10-24-2016 02:18 PM
'07 w/ P0208, P0308, P0300 ,P0301, P0316 codes TNGuy 2004 - 2008 F150 4 10-13-2016 04:49 PM
03 Expedition P0171 Help CycleVIN 1997-2006 Expedition & Navigator 10 02-24-2016 02:08 PM
P0720 Code on 2003 Excursion 6.8 V10 Paul T Modular V10 (6.8l) 15 08-25-2014 08:37 PM
05 Expedition P0430 Catalyst System Efficiency Below Threshold (Bank 2) WhyFord 1997-2006 Expedition & Navigator 35 07-06-2014 02:30 PM
Tags
2000, 2001, excursion, ford, location, o2, oxygen, replacing, sensor, sensors, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
