Broken dipstick ... - Ford Truck Enthusiasts Forums
Broken dipstick ...
Old 05-22-2012, 08:12 PM
caseys's Avatar
caseys caseys is offline
caseys has a good reputation on FTE.caseys has a good reputation on FTE.
Broken dipstick ...
Broke the handle off of the dipstick today on our 1996 Explorer Eddie Bauer 5.0...
... tried to get the stick out of the tube but it just shoved down to the choke point about an inch down the tube. Was able to remove it by using a new pencil and using a small dab of two-part epoxy sliding the flat pencil end down to mate with the broken dipstick. After setting up well I was able to pull the oil dipstick out.
Thinking I need something to plug the tube till I get a replacement dipstick I found out that an empty brass 38 caliber shell casing fits snug in the tube and stays put with just a couple light taps of a small hammer.
Now just gotta find someplace online to get a replacement dipstick. The metal part of the dipstick is 24 inches long. Figure I can get the dipstick/tube combo and just not use the new tube, but am finding that they are 20+ inches long and too short for what I need. Don't wanna get a junkyard dipstick since the handles are probably brittle on those too.
Any thoughts of a good online source ... ?
Old 05-23-2012, 10:17 AM
caseys's Avatar
Just ordered a Spectre 5723 dipstick from a guy on ebay ... will post how the length works out, the specs have it just over 25" (I forgot the exact length).
Old 05-24-2012, 04:29 PM
caseys's Avatar
Received the Spectre dipstick today ...this is NOT a good replacement for a broken dipstick on this Explorer. The dipstick is too short, will not fit down through the existing tube and the Spectre tube with NOT fit anywhere close on this Explorer.
What I have done is drilled out the rivets on the Spectre handle to retro-fit onto my original dipstick. Tomorrow I will be picking up the little replacement rivets and updating on my results.
Old 05-28-2012, 09:28 AM
caseys's Avatar
Broke the rest of the plastic off the old dipstick left from the broken handle. The old dip stick had a small hole in it for a pin that was holding on the handle. Picked up a couple of rivets (hammer peen type) and peen on the new handle in one of the holes. Attempted to drill the second hole into the old dipstick but the dang metal was too hard for my drill bit. The one rivet holds the new handle on tight so will wait until I pick up a better bit. The measurement is only about an 1/8 of on the short side when measuring the oil level.
Replacement Dipstick tubes gowild0706 Ford Inline Six, 200, 250, 4.9L / 300 14 12-01-2014 12:08 PM
Oil leak at flange, now dipstick tube is tweaked... nlemerise 1999 - 2003 7.3L Power Stroke Diesel 6 05-29-2012 11:53 AM
Oil dipstick handle..FIXED! (pics) DISLFVR 1999 - 2003 7.3L Power Stroke Diesel 7 01-01-2012 06:26 AM
Dipstick/Oil pan leak CAN be fixed!! RubberDuck 1994.5 - 1997 7.3L Power Stroke Diesel 31 10-23-2008 11:58 PM
Broken DipStick Tube jjlrrw 1997 - 2003 F150 4 09-30-2007 08:36 PM
Tags
250, 460, 73, broken, combo, dip, dipstick, end, ford, handle, idi, removing, stick, superduty, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
