Unusual idle
Unusual idle
I spent the better part of today searching and reading everything possibly related to what I am experiencing. In short, I did my homework, but nothing seems to be exactly the same as my "issue".
I put "issue" in quotes because issues can be mean little *******s and need to be caged, lest they infect other components.
Long story short:
When at idle, the truck (03 Ex. w/7.3) will lope a bit. By a bit, I mean 50-100 rpms every 5 seconds or so. This happens cold, hot, and everywhere in between. She also takes around 3-4 seconds of cranking to start. Occasionally there will be a small puff of white smoke, less than blowing out a drag of a cigarette, but nothing consistent, other than the lope.
Along with the lope comes a shudder. It happens on the up swing, and can be felt through the entire truck. Almost like a miss on a gasser. She gets up and goes, and has no other problems whatsoever. I don't know if I am just being picky, but I would like this to go away. My last diesel was a 94 F250 IDI. That thing never had any issues, and ran great. Maybe I just set my expectations too high.
So. I plan on checking the electrical connections, at the valve cover, and I have shot carb cleaner across every dang tube, pipe, hose, and fitting I could find. I even managed to spray myself right in the face, but that is another story.
Am I stupid, or is there something going on here? AFAIK it had a tune on it, at one point, which was removed. She has a 4" turbo back, an AFE intake, and a coolant filter plumbed in.
I am not afraid to turn a wrench (just replaced the motor in my Tahoe in my gravel driveway) and I am good at drinkin beer. Any suggestions along those lines will be appreciated.
Long story short:
The electrical connections along with the 50 cent mod are good for getting yourself familiar with the engine, however, generally speaking you will have a SES light with an electrical issue.
You could have mechanical injector issues i.e. worn poppets or internal orings. IPR's have been known to cause some loping, as well as a biased(oil contaminated) ICP sensor.
ICP sensor harness, and plug, are clean. Additionally, there is no change between being plugged in, or unplugged. She only has 125k on her, but I am the third owner, so God knows what all has been fooled with up until this point.
I have not looked at the IPR yet. I am still sifting through all the info to find a nice writeup on cleaning/testing.
Thanks, found it about 45 minutes age while searching yet again. I think my laptop is growing into my skin.
From my reading, the IPR is not a usual suspect for strange idle. I say strange because she does not idle rough. Not like a big cam, and not like pulling a spark plug creating a dead cylinder. It is more like the whole truck shakes like a wet dog for one second, then settles down. Maybe a dog is a bad analogy. It is not violent, it is more like a harmonic balancer out of whack, but only for that one second.
I am great at dealing with big issues: the drive shaft fell off, head needs to be pulled, etc., but little things like this drive me crazy!
Well this is just dandy.
I farted around under the hood for a bit today. Re-seated connectors, wiggled things around, and generally got dirty. I also added a half can of Seafoam to the oil. I fired the truck up, and it is idling perfectly.
I am not celebrating just yet, as it may be a fluke, but I am hopeful that my hamhandedness may have jarred something loose. I fully expect to have the same issue tomorrow, so ya'll can offer suggestions.
Seafoam, Lucas, and Marvel Mystery Oil can be a Godsend for stuck lifters and water intrusion issues. I just had about 6oz. left over and dumped it in. 6oz. will treat approx. 5 quarts of oil, and she just had a full 15 qt. change. I really don't think that the Seafoam fixed anything, there simply wasn't enough to make any kind of a real difference IMO.
I think that I probably did something when re-seating connectors but, since I touched all of them, I have no idea which one may have been the culprit. I believe that I will go out there this morning, only to find that the problem is still there. I am contemplating buying the AE system as I do not believe in throwing parts at a problem, nor in paying stealership prices.
What oil are you using ?? and how long since yor last oil change ?
I ask because when I changed from Shell Rotella 5-40 synthetic for winter back to regular Shell Rotella 15-40 for the summer months , my truck takes a little bit extra to start and also seems to have a different idle to it . I would think adding a can of Seafoam or whatever to the oil would help clean the injectors if they were starting to get gummed up from thicker oil in it .
That's my thinking , but I'm probably wrong .
Maybe someone will straighten me out !
Exactly where I am at. I have never heard another one idle like that, and I pay attention when a PSD starts up, but it is nice to know that someone else has the same thing.
i can attest though that it hasn't affected the reliability or performance of the truck at all so far.
I took a long weekend on the boat (Fri-Tuesday) and have yet to poke around anymore. The in-laws are coming on Monday, and the Wife is bound an determined to see me clean up my Tahoe project. On a positive note, she is probably going to get me an AE for my birthday next month so, hopefully, I will have some solid data to work with!
I have exactly the same problem here too. I have been searching the forums and I see it a lot, but never a solution. I have changed everything you could think of from IDM to all new injectors from DP, even a PCM about a year ago. UVCH on both sides when doing the injectors and glow plugs. EBP sensor and tube replaced, IPR replaced and the connector. I have tried several CPS's and even tried different weights of oil as well as synthetic and fossil. I have run it on my EA and even had a really good Diesel Tech look at it, he had no clue.
Tomorrow morning I am trying the fuel pump. I am open to any suggestion.
