Grinding from front wheel area at 20kph & above
Old 05-22-2012, 02:13 PM
paxmann's Avatar
paxmann
paxmann is offline
Any help would be greatly appreciated. I am getting a grinding sound from the left front wheel while driving straight.. The sound stays the same when brakes are applied and does not change when selecting 4wd or 2wd.. I pulled the wheel off and had a look, but saw nothing unusual.. Any thoughts on steps to diagnose/repair the issue?
04 F-150 5.4 4x4
Old 05-22-2012, 02:21 PM
danorules's Avatar
danorules
danorules is offline
Old 05-22-2012, 04:16 PM
paxmann's Avatar
paxmann
paxmann is offline
Thanks, that thread was great! I will post once problem solved..
Old 05-24-2012, 01:37 PM
paxmann's Avatar
paxmann
paxmann is offline
Update
After reading the thread everything you need to know about IWE's here is what I have found out; after disconnecting the line from the intake at the check valve sound is still present whether in 4low,high or 2wd it gets a little quieter when turning right. I found that the vac line coming from the left IWE is broken.. I will get on replacing that as soon as I can.. my concern now is since disconnecting the vacuum from the intake to the check valve made no difference I was hoping to make it drivable until I could replace the vac line.. anyway since it made no difference does this likely mean there are more issues other than the broken vac line... I am moving next week so I desperately need to make this truck drivable.. Help!!
Old 05-25-2012, 05:22 AM
60DRB's Avatar
60DRB
60DRB is offline
Might be a wheel bearing gone bad.
Old 05-25-2012, 10:50 AM
paxmann's Avatar
paxmann
paxmann is offline
bearing
Maybe I do have 2 separate issues, bearing and vacuum line.. Is it difficult to change the bearing? or does it come as a bolt on hub assy?
Old 05-26-2012, 10:08 PM
Greg B's Avatar
Greg B
Greg B is offline
I may be wrong, but I was under the impression that the front hubs need vacuum to keep them from engaging. Disconnecting would not help. The leak needs to be fixed.
jdhudall
2009 - 2014 F150
07-30-2017 10:57 PM
Yaz-Lariat
2004 - 2008 F150
06-05-2014 10:10 PM
JP2085
2004 - 2008 F150
06-24-2010 02:40 PM
bleoh
2004 - 2008 F150
26
05-27-2008 09:26 AM
Quick Reply: Grinding from front wheel area at 20kph & above
